TS3L301是一个16位至8位多路复用器/多路分解器局域网(LAN)开关,具有单选(SEL)输入。 SEL输入控制多路复用器/多路分离器的数据路径。
器件提供低且平坦的导通电阻(r on )和良好的导通状态电阻匹配。低输入/输出电容,高带宽,低偏斜和通道间低串扰使该器件适用于各种LAN应用,例如10/100/1000 Base-T。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
OFF-state leakage current (Max) (µA) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3L301 |
10 BASE-T 100 BASE-T 1000 BASE-T LVDS LAN |
2:1 SPDT |
8 |
3 |
3.6 |
4 |
0 |
5 |
600 |
900 |
-40 to 85 |
48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) |
TSSOP TVSOP |
-90 |
1 |
250 |
128 |
10 |
3.5 |
1 |
0.25 |
8 |
1.2 |
0.7 |
2 |
0.8 |
