一、电气特性
输入特性:
正向电压():通常对于这类光耦器件,其输入部分的发光二极管会有一个正向电压特性。可能在典型情况下,正向电压会处于一个相对较低的值,比如在 1.2V 到 1.5V 之间,具体数值取决于正向电流。当给输入引脚施加正向电流时,发光二极管会产生正向电压降,较低的正向电压有助于减少输入部分的功耗,方便与各种低功耗的控制器或驱动电路相配合。
正向电流():一般来说,为了使输入部分正常工作,会有一个典型的正向电流范围,可能在几毫安左右,例如 5mA 至 10mA。较小的正向电流要求意味着它可以很容易地被一些低功率的控制信号驱动,减少对前级电路的负载要求。
Forward voltage () : Usually for such optocoupler devices, the input part of the LED will have a forward voltage characteristic. Perhaps in typical cases, the forward voltage will be at a relatively low value, such as between 1.2V and 1.5V, depending on the forward current. When a forward current is applied to the input pin, the LED will produce a forward voltage drop, and the lower forward voltage helps to reduce the power consumption of the input part, which is convenient to cooperate with a variety of low-power controllers or drive circuits.
Forward current () : In general, in order for the input part to work properly, there will be a typical forward current range, which may be around a few milliamps, such as 5mA to 10mA. The small forward current requirement means that it can easily be driven by some low-power control signal, reducing the load requirement on the front stage circuit.
输入功耗:根据,结合上述可能的正向电压和正向电流范围,可以计算出输入部分的功耗范围,这对于评估整个系统的功耗分配以及电源设计是有帮助的。
According to the above possible forward voltage and forward current ranges, the power consumption range of the input part can be calculated, which is helpful for evaluating the power distribution of the entire system and the power supply design.
输出特性:
输出类型:可能是集电极开路输出或者推挽输出等。集电极开路输出可以方便地实现电平转换和逻辑功能的扩展,并且可以通过外部上拉电阻来实现不同的输出电平,而推挽输出则能提供较强的驱动能力,能输出高电平和低电平两种状态,驱动能力更强,适用于直接驱动负载。
Output type: May be open collector output or push-pull output, etc. The open-collector output can easily realize the level conversion and logic function expansion, and can achieve different output levels through the external pull-up resistor, and the push-pull output can provide a strong driving ability, can output high and low levels of two states, driving ability is stronger, suitable for direct drive load.
输出电流():对于集电极开路输出,其最大灌电流或拉电流能力可能在十几毫安到几十毫安之间;对于推挽输出,其输出电流能力可能更大,或许能达到上百毫安。这决定了它能够驱动多少负载,例如可以驱动多少个标准的 TTL 或 CMOS 逻辑门电路,或者能驱动多大功率的外部负载,如小型继电器、LED 等。
For open-collector output, the maximum filling current or pulling current capacity may be between tens of Ma and tens of Ma. For push-pull outputs, the output current capacity may be larger, perhaps up to hundreds of milliamps. This determines how much load it can drive, such as how many standard TTL or CMOS logic gates it can drive, or how much power it can drive external loads, such as small relays, leds, and so on.
输出电压():输出高电平和低电平的电压范围也很重要。高电平输出电压可能接近电源电压,而低电平输出电压则尽可能接近地电位,这样可以确保输出信号的逻辑电平能被后续电路准确识别。
The voltage range of the output high and low levels is also important. The high level output voltage may be close to the supply voltage, while the low level output voltage is as close as possible to the ground potential, which ensures that the logic level of the output signal can be accurately recognized by subsequent circuits.
二、光学特性
发光波长():很可能采用了一种高效的发光材料,常见的是红外或近红外光,比如发光波长在 800nm 至 900nm 左右。合适的发光波长有助于在输入和输出部分之间实现高效的光耦合,保证信号传输的可靠性和稳定性。
It is likely that an efficient luminescent material is used, which is commonly infrared or near-infrared light, such as the luminous wavelength of 800nm to 900nm. The appropriate luminous wavelength helps to achieve efficient optical coupling between the input and output parts, ensuring the reliability and stability of signal transmission.
电流传输比(CTR):这是一个关键参数,它表示输出电流与输入电流的比值。不同的工作条件下(如不同的输入电流、不同的温度等),CTR 可能会有所变化。通常在常温下,对于某个特定的输入电流,CTR 会有一个典型值,可能在百分之几十左右。例如,当输入电流为 5mA 时,CTR 可能为 30%,这意味着输出电流约为输入电流的 30%,即 1.5mA 左右。高 CTR 有助于在输入和输出之间实现更好的信号强度转换,确保信号不失真地从输入侧传输到输出侧。
This is a key parameter that represents the ratio of the output current to the input current. Under different operating conditions (such as different input currents, different temperatures, etc.), the CTR may vary. Usually at room temperature, for a specific input current, CTR will have a typical value, which may be in the tens of percent. For example, when the input current is 5mA, the CTR may be 30%, which means that the output current is about 30% of the input current, that is, about 1.5mA. High CTR helps achieve better signal strength conversion between input and output, ensuring that the signal is transmitted from the input side to the output side without distortion.
三、传输速度
数据传输速率:作为一款电子器件,其数据传输速率是评估其性能的重要指标。QX3H4 可能具有较高的数据传输速率,例如在几兆赫兹到几十兆赫兹的范围。这决定了它可以应用在一些对信号传输速度有要求的场合,如高速数据通信、高速开关电路、计算机外设接口等。在数字信号传输中,较高的数据传输速率能确保信号的及时和准确传输,避免因传输延迟导致的信号失真和误操作。
四、工作电压和耐压
工作电压():会有一个推荐的工作电压范围,可能从几伏到几十伏不等,如 5V 到 30V,这样可以适应不同的电源系统。同时,在输入和输出之间会有较高的隔离电压,比如可能达到数千伏的隔离电压,如 3000V 或更高。这种高隔离电压保证了输入和输出电路之间的电气隔离,防止电气干扰,提高系统的安全性和可靠性,在强电和弱电系统隔离、工业控制等应用中非常重要。
五、工作温度范围
温度范围:一般来说,该器件可以在较宽的温度范围内正常工作,例如从 - 40°C 到 + 85°C 甚至更宽的范围,如 - 55°C 到 + 125°C。这使得它能够适应各种不同的环境条件,从低温的户外环境到高温的工业环境,确保在不同温度下其电气、光学和传输性能的稳定性,使其可以应用于工业控制、汽车电子、航空航天等对温度有不同要求的领域。
六、封装形式
封装:可能采用常见的封装形式,如 SOP 封装、DIP 封装等。SOP 封装具有体积小、引脚间距小、适合表面贴装,适用于高密度电路板,有助于缩小电路板面积,降低产品体积;而 DIP 封装则便于手工焊接和实验测试,适用于对成本敏感、对电路板空间要求不高的场合。封装的尺寸和引脚布局会根据具体的封装形式而有所不同,设计人员可以根据自身需求选择合适的封装。
七、应用领域
工业控制:在工业自动化领域,可用于隔离输入输出信号,例如 PLC 的输入输出模块中,将外部的传感器信号与内部的控制器信号进行隔离,防止外部干扰进入内部系统,同时保证内部信号对外部执行器的安全可靠控制。
通信设备:在通信设备中,可用于实现不同模块之间的信号隔离和电平转换,保证高速信号在不同模块之间的准确传输,防止模块间的电气干扰,提高通信质量和稳定性,例如在网络交换机、调制解调器等设备中。
汽车电子:由于其宽温度范围和高可靠性,可应用于汽车的电子控制系统,如车身控制模块、发动机控制单元等,确保在汽车不同的运行环境下稳定工作,同时提供电气隔离,保障系统安全。
电源设备:在开关电源中,可作为隔离反馈信号的器件,将输出端的电压、电流等反馈信号可靠地传输到控制端,实现精确的电源调节和保护功能,提高电源的性能和可靠性。
光电耦合器
12文章
490浏览量
89555
成都恒利泰这款耦合器H3-MACP-009945耦合度怎么样啊 有知道的小伙伴吗
奥伦德光耦ORPC-817C DIP-4插件光电耦合器:隔离与信号传递的桥梁
FA40-220S24H3N4 FA40-220S24H3N4
东芝TLP5814H 具备增强安全功能的SiC MOSFET栅极驱动光电耦合器
夏普PC3H4替代群芯微驱动光电耦合器QX3H4美林美深
