为什么系统会自动回复RST报文呢?
冬至子 来源:Linux码农 作者:Linux码农 2022-11-16 17:19 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
先附代码
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define IP_DF        0x4000      /* Flag: "Don't Fragment"   */
//tcp 协议首部
typedef struct tcphdr {
    unsigned short  sport;//源端口
    unsigned short  dport;//目的端口号
    unsigned int    seq;//32位序列号
    unsigned int    ack_seq;//32位确认号
    unsigned char   len; // 首部长度
    unsigned char   flag; // 标志位
    unsigned short  window; //16位窗口大小
    unsigned short check; //16位校验和
    unsigned short  urg_ptr; //16位紧急指针
}TCPHDR;
//伪首部
typedef struct pseudohdr {
    unsigned int        saddr; //源ip
    unsigned int        daddr; //目的ip
    char                zeros; // 8为保留字节,为0
    char                protocol; //传输层协议号,tcp为6
    unsigned short      length; //16位tcp报文长度(tcp首部 + 数据)
}PSEUDOHDR;
// ip 协议首部
typedef struct iphdr {
    unsigned char   ver_and_hdrLen; // 版本号和ip头部长度
    unsigned char   tos; // 服务类型
    unsigned short  tot_len; // 总长度(首部和数据之和的长度)
    unsigned short  id; // IP包ID
    unsigned short  frag_off; // 标志位(包括分片偏移量)
    unsigned char   ttl; // 生命周期
    unsigned char   protocol; // 上层协议
    unsigned short  check; // 校验和
    unsigned int    saddr; // 源IP地址
    unsigned int    daddr; // 目标IP地址
}IPHDR;
//生成校验和,tcp校验和的计算包括: 12字节的伪首部 + tcp首部 + tcp数据
unsigned short  checkSum(unsigned short *buffer, unsigned short size)
    unsigned long cksum = 0;
    while (size > 1) {
        cksum += *buffer++;
        size  -= sizeof(unsigned short);
    if (size) {
        cksum += *(unsigned char *)buffer;
    cksum = (cksum >> 16) + (cksum & 0xffff);
    cksum += (cksum >> 16);
    return (unsigned short )(~cksum);
//ip头部初始化
void initIpHeader(IPHDR *iph, unsigned int saddr, unsigned int daddr)
    //syn 包只占用一个标记,不占用实际数据,因此报文中真实数据也就只是tcp首部
    int len = sizeof(IPHDR) + sizeof(TCPHDR);
    iph->ver_and_hdrLen = (4 << 4 | sizeof(IPHDR) / sizeof(unsigned int));
    iph->tos = 0;
    iph->tot_len = htons(len);
    iph->id = htons(1);
    //iph->frag_off = 0x40;
    iph->frag_off = htons(IP_DF);
    iph->ttl      = 255;
    iph->check = 0;
    iph->protocol = IPPROTO_TCP;
    iph->saddr = saddr;
    iph->daddr = daddr;
//tcp首部初始化
void initTcpHeader(TCPHDR *tcph, unsigned short sport, unsigned short dport)
    tcph->sport = htons(sport);
    tcph->dport = htons(dport);
    tcph->seq = htonl(rand() % 90000000 + 1234 );
    tcph->ack_seq = 0;
    //长度占4位
    tcph->len = (sizeof(TCPHDR)/4 << 4 | 0);
    //设置syn标记,其占第二个bit位
    tcph->flag = 0x02;
    tcph->window = htons(1024);
    tcph->check = 0;
    tcph->urg_ptr = 0;
//初始化tcp伪首部
void initPseudoHeader(PSEUDOHDR *phdr, unsigned int srcaddr, unsigned int dstaddr)
    phdr->zeros = 0;
    phdr->protocol = IPPROTO_TCP;
    phdr->length = htons(sizeof(struct tcphdr));
    phdr->saddr = srcaddr;
    phdr->daddr = dstaddr;
//构建 SYN 包
int createSynPacket(char *packet, int pkt_len, unsigned int saddr, unsigned short sport,
                    unsigned int daddr, unsigned short dport)
    char buf[512] = {0};
    int len = 0;
    IPHDR iph;             // IP 头部
    TCPHDR tcph;           // TCP 头部
    PSEUDOHDR pseudoh;     // TCP 伪头部
    memset(&iph, 0, sizeof(iph));
    memset(&tcph, 0, sizeof(tcph));
    memset(&pseudoh, 0, sizeof(pseudoh));
    len = sizeof(iph) + sizeof(tcph);
    // 初始化头部信息
    initIpHeader(&iph, saddr, daddr);
    initTcpHeader(&tcph, sport, dport);
    initPseudoHeader(&pseudoh, saddr, daddr);
    //计算IP校验和
    iph.check = checkSum((u_short *)&iph, sizeof(iph));
    // 计算TCP校验和
    memcpy(buf , &pseudoh, sizeof(pseudoh));           // 复制TCP伪头部
    memcpy(buf + sizeof(pseudoh), &tcph, sizeof(tcph)); // 复制TCP头部
    tcph.check = checkSum((u_short *)buf, sizeof(pseudoh) + sizeof(tcph));
    memset(packet, 0, pkt_len);
    memcpy(packet, &iph, sizeof(iph));
    memcpy(packet + sizeof(iph), &tcph, sizeof(tcph));
    return len;
//创建原始套接字
int createRawSocket(unsigned int saddr, unsigned short sport)
    int fd;
    int on = 1;
    struct sockaddr_in addr;
    // 创建一个原始套接字, 指定其关注TCP协议
    fd = socket(AF_INET, SOCK_RAW, IPPROTO_TCP);
    if (fd == -1) {
        return -1;
    addr.sin_family = AF_INET;
    addr.sin_port = htons(sport);
    addr.sin_addr.s_addr = saddr;
    /// 绑定
    int ret = bind(fd, (struct sockaddr*)&addr, sizeof(addr));
    if(-1 == ret)
        printf("bind error\\n");
        return -1;
    // 设置需要手动构建IP头部
    if (setsockopt(fd, IPPROTO_IP, IP_HDRINCL, (char *)&on, sizeof(on)) < 0) {
        close(fd);
        return -1;
    return fd;
void analyIPPack(IPHDR *ip)
    unsigned char *p = (unsigned char*)&ip->saddr;
    printf("Source IP : %u.%u.%u.%u\\n", p[0],p[1],p[2],p[3]);
    p = (unsigned char*)&ip->daddr;
    printf("dest IP : %u.%u.%u.%u\\n", p[0],p[1],p[2],p[3]);
void analyTCPPack(TCPHDR *tcp)
    printf("Source port : %u\\n", ntohs(tcp->sport));
    printf("Dest port : %u\\n", ntohs(tcp->dport));
    printf("Seq : %u\\n", ntohl(tcp->seq));
    printf("Ack seq : %u\\n", ntohl(tcp->ack_seq));
    printf("flag : %x\\n", tcp->flag);
    return;
//发送SYN包
int sendSynPacket(int sockfd, unsigned int saddr, unsigned short sport,
    struct sockaddr_in skaddr;
    char packet[256] = {0};
    int pkt_len = 0;
    memset(&skaddr, 0, sizeof(skaddr));
    skaddr.sin_family = AF_INET;
    skaddr.sin_port = htons(dport);
    skaddr.sin_addr.s_addr = daddr;
    pkt_len = createSynPacket(packet, 256, saddr, sport, daddr, dport);
    printf("send syn packet\\n");
    analyIPPack((IPHDR *)packet);
    analyTCPPack((TCPHDR *)(packet + sizeof(IPHDR)));
    return sendto(sockfd, packet, pkt_len, 0, (struct sockaddr *)&skaddr,
                  sizeof(struct sockaddr));
int main(int argc, char *argv[])
    unsigned int saddr;
    unsigned int daddr;
    int sockfd;
    char buf[1024] = {0};
    int len = 0;
    IPHDR * iphd = NULL;
    TCPHDR * tcphd = NULL;
    if (argc < 5) {
        fprintf(stderr, "Usage: syn );
        exit(1);
    saddr = inet_addr(argv[1]);  // 获取源IP
    sport = atoi(argv[2]);       // 获取源端口
    daddr = inet_addr(argv[3]);  // 获取目的IP
    dport = atoi(argv[4]);       // 获取目的端口
    sockfd = createRawSocket(saddr, sport); // 创建原始socket
    if (sockfd == -1) {
        fprintf(stderr, "Failed to make raw socket\\n");
        exit(1);
    if (sendSynPacket(sockfd, saddr, sport, daddr, dport) < 0) { // 发送SYN包
            fprintf(stderr, "Failed to send syn packet\\n");
    while(1)
        len = recv(sockfd, buf, sizeof(buf), 0);
        if(len == -1)
            fprintf(stderr, "recv error %d %s\\n", errno, strerror(errno));
            return 0;
        else if(len == 0)
            continue;
        else
            break;
    printf("\\n recv msg len %d \\n", len);
    iphd = (IPHDR *)buf;
    tcphd = (TCPHDR *)(iphd + 1);
    analyIPPack(iphd);
    if(iphd->protocol == IPPROTO_TCP)
        analyTCPPack(tcphd);
    close(sockfd);
    return 0;
运行结果:
# ./synack  10.223.12.10 1234  10.223.12.20 4567
send syn packet
Source IP : 10.223.12.10
dest Ip : 10.223.12.20
Source port : 1234
Dest port : 4567
Seq : 4290617
Ack seq : 0
flag : 2
recv msg len 44
Source IP : 10.223.12.20
dest Ip : 10.223.12.10
Source port : 4567
Dest port : 1234
Seq : 1510433077
Ack seq : 4290618
flag : 12
在 10.223.12.20 上抓包结果
# tcpdump -i eth0 port 4567
02:03:04.641657 IP 10.223.12.10.dbm > localhost.localdomain.personal-agent:
Flags [S], seq 4290617, win 1024, length 0
02:03:04.641707 IP localhost.localdomain.personal-agent > 10.223.12.10.dbm:
Flags [S .], seq 1510433077, ack 4290618, win 29200, options [mss  1460], length 0
02:03:04.641812 IP 10.223.12.10.dbm > localhost.localdomain.personal-agent:
Flags [R], seq 4290618 win 0, length 0
从结果中可以看到 10.223.12.10 在接收到对端回应的 syn + ack 后,系统会自动给对端回应一个 RST 复位报文,导致二者的链路断开。
为什么系统会自动回复 RST 报文呢?
首先先分析客户端收到对端回应的 syn+ack 会发生什么。
在网络层把数据包发送到传输层时,会调用 ip_local_deliver_finish ,在该函数中会将报文复制一份给 RAW 套接口,然后会继续往下处理,最终会进入到 tcp 的接收函数 tcp_v4_rcv,在该函数中会进行套接字的查找。
int tcp_v4_rcv(struct sk_buff *skb)
    /*从ehash或bhash中根据地址和端口查找传输控制块。
    若在ehash中找到,表示3次握手后已建立起了连接,可以正常通信。
    若在bhash中找到,表示已经绑定了端口,处于监听状态。
    若都找不到,说明对应的传输控制块还没有创建,跳转*/
    sk = __inet_lookup(&tcp_hashinfo, skb->nh.iph->saddr, th->source,
               skb->nh.iph->daddr, th->dest,
               inet_iif(skb));
    if (!sk)
        goto no_tcp_socket;
//处理没有创建传输控制块收到的报文情况,通常给对方发送RST段
no_tcp_socket:
    //查找IPSec策略数据库,查找失败跳转
    if (!xfrm4_policy_check(NULL, XFRM_POLICY_IN, skb))
        goto discard_it;
    /* 检测报文的长度和校验和,若有异常说明报文已损坏,统计后丢弃,
       否则给对端发送rst段后丢弃*/
    if (skb->len < (th->doff << 2) || tcp_checksum_complete(skb)) {
bad_packet:
        TCP_INC_STATS_BH(TCP_MIB_INERRS);
    } else {
        tcp_v4_send_reset(NULL, skb);
// 丢弃数据包
discard_it:
    /* Discard frame. */
    kfree_skb(skb);
      return 0;
discard_and_relse:
    sock_put(sk);
    goto discard_it;
//处理传输层控制块处于TIME_WAIT状态的情况
do_time_wait:
从上述代码可知,当客户端接收到报文后,先调用 __inet_lookup 查找传输控制块,由于原始套接字没有创建传输控制块,因此会跳到 no_tcp_socket 处发送 RST 报文给对端。
在 TCP 中,对于客户端来讲,当客户端调用 connect 时,会在 hash 表tcp_hashinfo 中加入传输控制块,以便后续接收报文中能够找到对应的套接字。
tcp_v4_connect
   -> inet_hash_connect
      -> __inet_check_established
对于原始套接字,其没有端口号的概念,因此也就不会再hash表中存放传输控制块,收到报文也就找不到对应的socket,所以收到 SYN 报文后,系统会自动给对端恢复 RST 复位报文。
审核编辑:刘清
  • SYN
    SYN
  • RST
    RST
  • RAW
    RAW
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    w5500 作为tcp server,客户端异常发送【RST,ACK】断开连接问题
    报文;查了下非异常报文,但是能否把这个报文去掉,手册未找到对应寄存器 2.RST报文可能的原
    发表于 10-14 14:01
    转载:基于labview的自动回复程序
    WebBrowser控件和Microsoft HTML Object Library的应用,用于论坛自动回复
    发表于 12-03 14:49
    怎么没回复!!!
    {:2:}{:2:}{:2:}{:2:}{:2:}怎么没回复!!!人员不行还是???
    发表于 03-29 20:00
    CANopen SDO通讯 客户端总是回复中断传输报文
    使用电脑和驱动器进行信号传输,驱动器处于预操作状态电脑发送SDO请求报文,但是驱动器的回复报文数据位总是00 00 02 06,我查了下这是SDO的abort transfer,表示对象字典中的对象不存在;换了其他的索引,不管是
    发表于 11-14 16:58
    14-TCP 协议(连接异常与RST
    release)。也可以通过发送 RST 段给对端来释放连接,这种方式称为异常释放(abortive release)。异常终止连接有两个特点:丢弃任何尚未发送的数据,立即发送 RST 报文
    发表于 07-24 10:01
    使用AT组件+SIM7600如何处理HTTP报文
    ;.....}\\r\\n [http报文]rece:+HTTPREAD: 0\\r\\n如何 [http报文]如果使用at_exec_cmd.. 忽略OK之后的报文。如果
    发表于 09-08 11:11
    ubuntu RS485 编程 出现回复报文的数据混乱
    发送的指令有了相应的操作来判断的),但是保护装置回复报文明显是错的,因为正确的报文应该与我发送给它的指令是一致的。 我用cutecom测试了一下,cutecom是可以正确接收保护装置返回的
    发表于 11-01 09:27
    请教大神AT组件如何处理去http报文
    [http报文]rece:+HTTPREAD: 0\\r\\n如何 [http报文]如果使用at_exec_cmd.. 忽略OK之后的报文。如果使用urc识别:关键字设置+HTTP
    发表于 02-14 09:56
    工业自动系统制造报文规范:第4部分数值控制用伴同标准
    工业自动系统制造报文规范第4部分数值控制用伴同标准 GB/T 16720.4-1998
    发表于 01-13 23:20 12次下载
    工业<b class='flag-5'>自动</b>化<b class='flag-5'>系统</b>制造<b class='flag-5'>报文</b>规范:第4部分数值控制用伴同标准
    基于FPGA深度报文检测系统
    针对当前采用正则表达式匹配的深度报文检测系统匹配效率低下,难以满足高速网络线速处理的问题,本文提出了一种基于现场可编程门阵列(Field Programmahle Gate ArraV,FPGA
    发表于 11-10 11:06 7次下载
    基于FPGA深度<b class='flag-5'>报文</b>检测<b class='flag-5'>系统</b>
    基于离散序列报文自动提取算法
    针对缺少会话信息的离散序列报文,提出一种基于离散序列报文的协议格式( SPMbFSC)特征自动提取算法。SPMbFSC在对离散序列报文进行聚类的基础上,通过改进的频繁模式挖掘算法提取出
    发表于 12-04 10:19 0次下载
    关于tcp协议栈中rst报文的seq跳变问题
    导致内核协议栈发送了一个rst报文,而rst报文选取seq的时候,并不是选取的确定已经发送的seq,而是当前连接已经用掉的seq,也就是当前seq,哪怕这个
    的头像 发表于 07-27 15:26 5539次阅读
    关于tcp协议栈中<b class='flag-5'>rst</b><b class='flag-5'>报文</b>的seq跳变问题
    AI智能如何自动回复
    在节省成本的同时,准确快速的自动回复也可以大大提高工作效率和客户满意度。
    发表于 06-28 10:59 8249次阅读
    区域短报文和全球短报文服务的区别在哪里
    北斗系统是全球首个提供区域短报文通信服务和全球短报文服务的卫星导航系统,目前在边防、水利、林业、电力、海上通信等各个行业应用。支持北斗短报文
    的头像 发表于 11-24 16:38 5156次阅读
    应用笔记 | TSMaster如何代码自动发送LIN报文
    前面我们出了关于TSMaster应用笔记系列的几篇文章,小伙伴反馈都非常实用,也是工程师们在使用TSMaster软件中切切实实遇到的问题,今天继续给大家带来应用笔记系列文章——如何代码自动发送
    的头像 发表于 08-25 11:05 3084次阅读
    应用笔记 | TSMaster如何代码<b class='flag-5'>自动</b>发送LIN<b class='flag-5'>报文</b>
