DS2152 - Telecom Evaluation Board
2023-03-22 19:54:49
DS2154 - Telecom Evaluation Board
2023-03-22 19:54:49
JUMPER02DS-8E-02DS-8E6"
2023-03-22 22:25:42
JUMPER02DS-8E-02DS-8E12"
2023-03-22 22:25:42
JUMPER02DS-8E-02DS-8E2"
2023-03-22 22:25:39
JUMPER03DS-8E-03DS-8E6"
2023-03-22 22:25:56
JUMPER03DS-8E-03DS-8E2"
2023-03-22 22:25:55
JUMPER04DS-8E-04DS-8E6"
2023-03-22 22:25:42
JUMPER04DS-8E-04DS-8E12"
2023-03-22 22:25:43
JUMPER05DS-8E-05DS-8E6"
2023-03-22 22:25:59
JUMPER05DS-8E-05DS-8E12"
2023-03-22 22:26:01
JUMPER06DS-8E-06DS-8E12"
2023-03-22 22:25:47
JUMPER06DS-8E-06DS-8E2"
2023-03-22 22:25:44
JUMPER07DS-8E-07DS-8E12"
2023-03-22 22:26:06
JUMPER08DS-8E-08DS-8E2"
2023-03-22 22:25:45
JUMPER09DS-8E-09DS-8E6"
2023-03-22 22:26:07
JUMPER09DS-8E-09DS-8E12"
2023-03-22 22:26:11
JUMPER09DS-8E-09DS-8E2"
2023-03-22 22:26:05
JUMPER10DS-8E-10DS-8E2"
2023-03-22 22:26:06
JUMPER11DS-8E-11DS-8E6"
2023-03-22 22:26:12
JUMPER12DS-8E-12DS-8E6"
2023-03-22 22:26:15
JUMPER12DS-8E-12DS-8E2"
2023-03-22 22:26:13
JUMPER13DS-8E-13DS-8E12"
2023-03-22 22:26:20
JUMPER13DS-8E-13DS-8E2"
2023-03-22 22:26:13
JUMPER14DS-8E-14DS-8E6"
2023-03-22 22:26:18
JUMPER14DS-8E-14DS-8E12"
2023-03-22 22:26:21
JUMPER15DS-8E-15DS-8E6"
2023-03-22 22:26:19
JUMPER15DS-8E-15DS-8E12"
2023-03-22 22:26:22
JUMPER15DS-8E-15DS-8E2"
2023-03-22 22:26:14
INTRODUCTIONThere are several methods available for interfacing 1-WireTM devices
2009-04-18 10:18:3028 Interfacing the DS18X20/DS1822 1-Wire Temperature Sensor in a Microcontroller Environment
2009-05-08 11:37:5420 This app note shows how to connect a DS1390 to a Motorola DSP that has a built-in SPIinterface
2010-04-25 10:21:1018 The DS1390 Real-Time Clock (RTC) may be interfaced with a microcontroller (μC) or Digital Signal
2010-05-29 08:37:4911 Abstract: This application note introduces the user to software for interfacing a DS5000 (8051
2009-04-18 10:28:04678 Abstract: Communication with the DS1620 digital temperature sensor IC is achieved via a simple
2009-04-18 10:46:14751 ) is ideal for applications such as data logging. This application note examines temperature-measuring techniques interfacing to the DS1620 dig
2009-04-18 10:48:58562 摘要:本应用笔记讨论了用D1版的DS2154代替A2版的DS2154时可能会遇到的问题。尽管D1版的DS2154可直接替代A2版的DS2154,但是,替换器件后用户还是有可能遇到一些有关定时方面的问题。
2009-04-18 12:03:28694 Abstract: This application note highlights the differences between the DS2154L and the DS2153Q E1
2009-04-20 09:27:16870 processor to many of the Dallas Semiconductor single chip transceivers (SCTs). The application note covers interfacing both the address and dat
2009-04-20 09:35:221061 Transceivers: DS2151, DS2152, DS2153, DS2154, DS21552, DS21554, DS21352, DS21354 and DS2155. Specifications for selecting the approp
2009-04-20 09:38:44760 channels. The idle registers in the DS2152, DS2154, DS21X5Y and DS2155 can be used to fill unused (if any) channels. The used channels do not
2009-04-20 09:43:04774 processor to the DS2155 T1/E1/J1 Single Chip Transceiver (SCT). The application note covers interfacing both the address and data processor bus
2009-04-20 09:46:53575 /Maxim Communications Products DS21354/DS21554 and DS2154 single chip transceivers (SCTs). The additional features contained in the DS21354/DS21
2009-04-20 10:12:59807 Abstract: This application note will help with the migration from a current design using the DS2152
2009-04-20 10:13:54653 Semiconductor/Maxim DS2154 and DS2152 single chip transceivers (SCTs). Figure 1 logically describes the clock map of the DS2152 and
2009-04-20 10:21:38788 DS2152/DS2154 T1/E1 demo kits. The DS2152DK & DS2154DK are ordered and shipped for either T1 or E1 operation. However,
2009-04-20 10:24:12747 processor to the DS2141Q or the DS2143Q Dallas Semiconductor T1 or E1 framers. The application note covers interfacing both the address and da
2009-04-20 10:29:40583 Abstract: Different values of resistor can be selected between DS2153 or DS2154 single chip
2009-04-20 10:30:24624 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:31:04536 Abstract: This application note provides a logical diagram of the interface of the Dallas Semiconductor/Maxim DS2151 and DS2153 to the PMC-Sierra 7345.
2009-04-20 10:32:06686 /Maxim DS2152 or DS2154 single chip tranceivers (SCTs) to the IGT ALL1 SAR (WAC-021-C). Interconnections between the DS215
2009-04-20 10:33:30607 Abstract: The DS2151, DS2152, DS2153 and DS2154 single chip transceivers (SCTs) can be used
2009-04-20 10:34:09929 Abstract: This application note will describe the interconnections between the DS2152 or DS2154
2009-04-20 10:34:47698 Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the Motorola MC68MH360 QUICC32. Interconnections be
2009-04-20 10:35:31568 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:37:00899 Abstract: Interfacing between the Hitachi HD64570 and the DS2151 for T1 lines or the DS2153 for E1 lines. MCSI-0 and MCS-1 are in Bit Synchronous
2009-04-20 10:38:06750 Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the Siemens PEB20320.
2009-04-20 10:38:51830 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:41:16744 Abstract: Application note 303 provides information on connecting the DS2151 and DS2153 single chip
2009-04-20 10:42:38840 Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the AT&T T7270.
2009-04-20 10:43:22578 Abstract: This application note shows connection of the DS2151 T1 single chip transceiver
2009-04-20 10:44:041043 system backplane using the Dallas Semiconductor/Maxim DS2152 and DS2154 T1/E1 single chip tranceivers (SCTs). The DS2155, DS26528, DS26524, DS
2009-04-20 10:46:001036 Abstract: This application note show how to connect the DS21x5y family of single chip transceivers
2009-04-20 10:46:57672 registers. In order to derive those functions, we need to use the test registers of the following devices: DS21Q42, DS21Q44, DS2152, DS2154, D
2009-04-20 10:48:32851 Abstract: The following application note shows simple circuits using the DS1814 MicroMonitor.
2009-04-23 09:25:16619 ) is ideal for applications such as data logging. This application note examines temperature-measuring techniques interfacing to the DS1620 dig
2009-04-23 10:28:461120 Abstract: This application note introduces the user to software for interfacing a DS5000 (8051
2009-04-23 14:40:071737 the Maxim DS2760 Battery Monitor and Protector IC to a microcontroller. The DS5000 microcontroller module is used for example purposes. Both h
2009-04-23 14:43:281102 Abstract: This application note introduces the user to software for interfacing a DS5000 (8051
2009-04-23 15:02:56896 Abstract: The following application note shows simple circuits using the DS1814 MicroMonitor.
2009-04-23 15:11:01666 Abstract: The DS1868 uses a dual digital potentiometer with a 3-wire (shift register) interface.
2009-04-28 11:57:28715 /Maxim Communications Products DS21354/DS21554 and DS2154 single chip transceivers (SCTs). The additional features contained in the DS21354/DS21
2009-04-29 10:02:291541 Abstract: This application note will help with the migration from a current design using the DS2152
2009-04-29 10:03:34568 Semiconductor/Maxim DS2154 and DS2152 single chip transceivers (SCTs). Figure 1 logically describes the clock map of the DS2152 and
2009-04-29 10:12:051523 DS2152/DS2154 T1/E1 demo kits. The DS2152DK & DS2154DK are ordered and shipped for either T1 or E1 operation. However,
2009-04-29 10:14:011059 processor to the DS2141Q or the DS2143Q Dallas Semiconductor T1 or E1 framers. The application note covers interfacing both the address and da
2009-04-29 10:15:34698 Abstract: Different values of resistor can be selected between DS2153 or DS2154 single chip
2009-04-29 10:16:571062 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-29 10:18:40496 Abstract: This application note provides a logical diagram of the interface of the Dallas Semiconductor/Maxim DS2151 and DS2153 to the PMC-Sierra 7345.
2009-04-29 10:19:22665 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-29 10:20:011154 Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-29 10:21:40752 system backplane using the Dallas Semiconductor/Maxim DS2152 and DS2154 T1/E1 single chip tranceivers (SCTs). The DS2155, DS26528, DS26524, DS
2009-04-29 10:24:571000 Abstract: Application Note 349 provides a detailed list of the features included in the DS2152
2009-04-29 10:25:42881 ds2154数据手册
2016-12-26 21:59:460 Interconnections between the DS2151 or DS2153 and the Motorola MC68MH360 (QUICC32) are shown
2017-04-10 10:26:494 2022-11-18 23:45:260 本应用笔记列出了Maxim通信产品DS21354/DS21554和DS2154单芯片收发器(SCT)之间的差异。本文重点介绍了DS21354/DS21554中包含的附加功能,以及支持HDLC控制器、交错总线操作(IBO)和JTAG等新功能所需的附加寄存器。
2023-01-12 11:40:18599 本应用笔记提供了使用DS2152和DS2154的现有应用开始使用较新的DS21552、DS21352、DS21554和DS21354单芯片收发器(SCT)的要求。包括对最新器件的附加功能、JTAG IEEE 1149.1边界扫描和交错PCM总线操作的讨论。
2023-01-13 14:22:04535 本应用笔记介绍了E1收发器芯片接口电路的一般形式,并展示了如何在变压器周围分配电阻。它解释了为什么发射器和接收器引脚需要不同的保护技术。它讨论了回波损耗的重要性,并展示了如何计算它。内置DS2153/DS2154 E1单芯片收发器IC。
2023-01-13 15:13:26634 电子发烧友网为你提供Maxim(Maxim)DS2152L相关产品参数、数据手册,更有DS2152L的引脚图、接线图、封装手册、中文资料、英文资料,DS2152L真值表,DS2152L管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 18:49:23
电子发烧友网为你提供Maxim(Maxim)DS2152L+相关产品参数、数据手册,更有DS2152L+的引脚图、接线图、封装手册、中文资料、英文资料,DS2152L+真值表,DS2152L+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:47:02
电子发烧友网为你提供Maxim(Maxim)DS2154LNA2+相关产品参数、数据手册,更有DS2154LNA2+的引脚图、接线图、封装手册、中文资料、英文资料,DS2154LNA2+真值表,DS2154LNA2+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-23 19:54:46
电子发烧友网为你提供Maxim(Maxim)DS2154LN相关产品参数、数据手册,更有DS2154LN的引脚图、接线图、封装手册、中文资料、英文资料,DS2154LN真值表,DS2154LN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-23 19:56:31
电子发烧友网为你提供Maxim(Maxim)DS2154LA2+相关产品参数、数据手册,更有DS2154LA2+的引脚图、接线图、封装手册、中文资料、英文资料,DS2154LA2+真值表,DS2154LA2+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-24 20:08:53
电子发烧友网为你提供Maxim(Maxim)DS2154L相关产品参数、数据手册,更有DS2154L的引脚图、接线图、封装手册、中文资料、英文资料,DS2154L真值表,DS2154L管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-26 19:14:42
电子发烧友网为你提供Maxim(Maxim)DS2154L+相关产品参数、数据手册,更有DS2154L+的引脚图、接线图、封装手册、中文资料、英文资料,DS2154L+真值表,DS2154L+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-27 18:37:28
电子发烧友网为你提供Maxim(Maxim)DS2154LN+相关产品参数、数据手册,更有DS2154LN+的引脚图、接线图、封装手册、中文资料、英文资料,DS2154LN+真值表,DS2154LN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-27 18:40:23
电子发烧友网为你提供Maxim(Maxim)DS2154LD2+相关产品参数、数据手册,更有DS2154LD2+的引脚图、接线图、封装手册、中文资料、英文资料,DS2154LD2+真值表,DS2154LD2+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-27 20:05:01
本应用笔记有助于从使用DS2152单芯片收发器(SCT)的电流设计过渡到使用DS21352或DS21552 SCT的设计。
2023-02-07 16:34:49557 本应用笔记重点介绍DS2152L和DS2151Q T1单芯片收发器的区别。DS2152L是DS2151Q的超集。DS2151Q的所有原始特性都得以保留,为DS2151Q创建的软件可以毫不费力地转移到DS2152L上。
2023-06-13 16:31:24345
查看更多
