电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Overvoltage Protection in Auto
收藏
查看更多
auto cad2007
哪位楼主有 auto cad2007 视频教程或在哪里可以下载!我在学习这个软件,谢谢!
2014-01-07 21:57:35
BS 6651 pdf (Lightning Protection)
Lightning Protection – IntroductionStructural lightning protection design considerationsBS 6651
2009-05-25 15:57:08
C6678 CorePac中的Memory Protection与Error Detection and Correction
除了TMS320C66x DSP CorePac User Guide中的Chapter 10 Memory Protection与Chapter 11 Error Detection
2018-07-24 09:19:50
ESD Protection Array SOD-523 Series
2014-03-25 18:19:56
FR9889经典降压芯片,代理含税FR9889
protection includes cycle-by-cycle current limit, UVLO, output overvoltage protection and thermal
2020-10-23 09:26:10
MAX4505EUA
IC OVERVOLTAGE PROTECTION 8UMAX
2023-04-06 11:12:30
MAX4506CSA
IC OVERVOLTAGE PROTECTION 8SOIC
2023-03-23 04:56:09
MAX4838AELT+T
OVERVOLTAGE-PROTECTION
2023-04-06 11:12:41
MAX4838AEXT+T
2023-04-06 11:12:42
MAX4840AELT+
2023-03-27 14:12:35
MAX4840AELT+T
2023-04-06 11:12:06
MAX4842AELT+T
2023-04-06 11:12:41
MAX4844ELT+T
2023-04-06 11:12:41
MAX4846ELT+T
2023-04-06 11:12:46
MAX4893BETB+T
2023-04-06 11:12:41
OnSemi NPC1337 60W适配器参考设计方案
Circuit Protection Independent of Auxiliary Voltage  Overvoltage Protection  Brown Out Protection  Two
2018-09-26 16:03:12
PLC控制器单元中的输入电源路径保护和备用电源设计方案
描述This TI Design provides a solution for input power path protection and backup supply design in a
2018-12-06 14:06:11
Protect Current-Sense Amplifiers from Negative Overvoltage
the ESD-protection diodes. This circuit protects a particular high-side current-sense amplifier (MAX4080
2011-08-21 16:49:34
Solid State Overvoltage Protector for AC Line
protection againsttransient voltage conditions because it is very common thatthese types of equipment
2009-05-12 13:23:05
USB Type-C应用中的电源路径保护解决方案
(...)主要特色Reverse current blocking and overvoltage protection up 30 VOvercurrent events and short-circuit
2018-12-05 14:05:54
[推荐]Call for Papers: Journal of Water Resource and Protection (JWARP)
and Protection http://www.scirp.org/journal/jwarp/ ISSN 1945-3094 (print), 1945-3108 (Online
2009-02-06 15:45:44
【PDF】ESD (Electrostatic Discharge) Protection in CMOS Integrated Circuit
...............................................................................1ESD (Electrostatic Discharge) Protection in CMOS Integrated Circuits ..........................1目录
2011-02-24 09:55:18
代理天钰FP6715,1A同步升压IC芯片
with Auto Recovery Output Overvoltage Protection Space-Saving SOT-23-6 PackageApplications Portable
2020-10-28 10:27:14
代理天钰FR9801降压转换器芯片
 Over-Temperature Protection with Auto Recovery Output Overvoltage Protection Under Voltage Lockout
2020-10-24 09:30:40
代理天钰FR9886降压转换器芯片,SOP8封装
● Adjustable Soft-Start● Cycle-by-Cycle Current Limit● Over-Temperature Protection with Auto Recovery● Output Overvoltage Protection● Under Voltage Lockout●
2020-10-24 09:26:13
低电压1.8V升5V,输出峰值电流11A高效率同步升压-ZCC2007
Shutdown Current <1μA Over-Current and Short-Circuit Protection Output Overvoltage Protection
2024-01-30 17:20:50
汽车12V/24V电池输入保护参考设计包括BOM及层图
protections required are overvoltage, overload, reversepolarity, and jump start. During the life of a
2018-09-28 08:53:41
汽车类远程USB充电端口电源管理设计
, to(...)主要特色Complete power solution for a remote USB charging portInput overvoltage protection for surge
2018-11-01 16:32:03
用于CGG3器件的VBuSUP过电压保护
the CCG3 (CYPD3125) have overvoltage protection on VBUS_P since it controls the gate
2018-08-27 14:38:23
英飞凌基于ICLS8082G带PFC和调光的离线LED控制的设计方案
limitation• Auto restart mode for output overvoltage protectionAuto restart mode for short circuit
2018-12-06 09:50:09
请问c6678 memory protection是在什么上面来体现的
,另一方面是实现存储保护功能,即memory protection,请问memory protection是在什么上面来体现的,或者说xmc怎么实现memory protection的?2 external
2018-12-29 11:39:51
适用于汽车系统的反极性和过压保护参考设计
描述PMP10737 is a reference design that provides protection from reverse polarity (LM74610 Smart
2018-08-28 10:35:52
MAX4978, MAX4979 pdf datasheet
The MAX4978–MAX4981 overvoltage-protection devices protect low-voltage systems against voltage
2008-09-06 00:07:5016
MAX4980, MAX4981 pdf,MAX4980,
2008-09-06 00:08:4920
pdf protection下载 (PDF Protecti
PDF Protection Manager 1.1 Description "Application for add/change/remove standard
2008-10-12 02:14:5779
MAX14527/MAX14528 pdf datashee
The MAX14527/MAX14528 overvoltage protection devices feature a low 100mΩ (typ) RON internal FET
2008-11-27 17:33:1219
MAX6495 pdf datasheet (72V,Overvoltage-Protection Switches/Limiter Controllers)
The MAX6495–MAX6499 is a family of small, low-current, overvoltage-protection circuits
2009-01-11 11:43:2932
MAX6397, MAX6398 pdf datasheet
The MAX6397/MAX6398 are small, high-voltage overvoltage protection circuits. These devices
2009-01-22 15:15:1815
MAX14529E, MAX14530E pdf datas
The MAX14529E/MAX14530E are overvoltage-protection devices with USB charger detection
2009-02-19 16:25:4725
Demystifying Auto-Zero Amplifiers—1
Demystifying Auto-Zero Amplifiers—Part 1:Whenever the subject of auto
2009-09-23 22:56:177
Demystifying Auto-Zero Amplifiers—2
Demystifying Auto-Zero Amplifiers—2:They essentially eliminate offset, drift
2009-09-23 22:56:5012
Comprehensive Fault Protection
Comprehensive Fault Protection Features Designed for High-Reliability Systems Using LM3743
2009-09-30 09:55:067
Auto-tester ATC40-1用户使用手册
Auto-tester ATC40-1用户使用手册:在使用 Auto-tester的过程中必须注意下列安全规定,如不遵守本规定,产品功能可能受损并危及人身安全。注意:1. 勿在腐蚀性的环境、蒸气或灰
2009-10-01 14:26:4312
Designing auto power systems w
Designing auto power systems with ultracapacitors:Over the last decade, advances in materials
2009-10-01 18:42:2312
ESD Protection Audio Input and
Electronic systems are sensitive toboth external and internal sourcesof overvoltage transients.
2009-10-19 10:21:3814
ESD Protection Design Seminar(
ESD Protection Design Seminar: What is ESD? What damage can it cause? Why is the problem
2009-11-26 10:17:3016
NCP346 Overvoltage Protection
The NCP346 Overvoltage Protection circuit (OVP) protectssensitive electronic circuitry from
2009-11-26 11:33:3224
TPS3510 TPS2511 PC POWER SUPPL
supplysystems. It provides protection circuits, power good indicator, fault protection output (FPO) and PSON control.Overvoltage protection (OVP
2009-12-05 15:21:5037
Smart FET Protection Features
Smart FET Protection Features Agenda• Current Limit• Over Temperature Protection• Over Voltage
2010-04-16 10:55:1217
Using the ADS8328 in Auto Trig
This application report presents one solution for interfacing the ADS8328, configuredfor auto
2010-06-03 14:22:5733
PROFET® Preliminary Data S
• Overtemperature protectionOvervoltage protection (including load dump)• Clamp of negative voltage at
2010-07-01 12:00:3217
POWR-GARD Protection Relays an
DescriptionThe PGR-6100 Ground-Fault & Insulation Relay is designed to provide basic protection
2010-08-26 14:25:2619
TPS2400,pdf(Overvoltage Protec
The TPS2400 overvoltage protection controller is used with an external N-channel MOSFET to isolate
2010-10-28 21:50:5020
BQ29200,BQ29209,pdf(Voltage Pr
The bq2920x device is a secondary overvoltage protection IC for two-series cell lithium-ion battery
2010-11-10 12:37:3316
bq29440,bq29449,bq2944L9,pdf(V
The bq2944x is a secondary overvoltage protection IC for 2-series, 3-series, or 4-series cell
2010-11-10 12:59:2218
BQ2944L0,pdf(Voltage Protectio
2010-11-10 13:05:189
BQ77PL157A4225,pdf(Stackable S
The bq77PL157 is a stackable overvoltage protection device for 3, 4, 5 or 6 series cell Li-Ion
2010-11-10 13:08:2940
bq29410,bq29411,bq29412,bq2941
The bq2941x is a secondary overvoltage protection IC for 2-, 3-, or 4-cell lithium-ion battery
2010-11-10 13:15:1930
BQ24312,pdf(Overvoltage and Ov
The bq24312 is a highly integrated circuit designed to provide protection to Li-ion batteries from
2010-11-10 14:53:0512
BQ24314A,pdf(Overvoltage & Ove
The bq24314A is a highly integrated circuit designed to provide protection to Li-ion batteries from
2010-11-10 15:20:2316
auto cad2007快捷键
auto cad2007快捷键 F1: 获取帮助F2: 实现作图窗和文本窗口的切换F3: 控制是否实
2008-01-03 23:23:111834
AUTO CAD2008快捷键命令大全
AUTO CAD2008快捷键命令大全 (一)字母类
2008-01-03 23:24:2628290
使用Auto CAD2000打印输出图纸的几点经验与技巧
 使用Auto CAD2000打印输出图纸的几点经验与技巧 Auto CAD2000是最新版本的计算机辅助绘图工具软件,和早期版本相比增加了许多新功能,
2009-02-14 17:07:201164
Auto CAD环境下实现制表功能
Auto CAD环境下实现制表功能一、说明:   使用过Auto CAD的工程技术人员,时常需要在工程图中加一些表格, 对所设计的产品加以归纳说明,而AutoCAD环境下没有
2009-02-14 17:10:001339
Flexible Fault Protection
from the user or other fault-indicating signal. It accommodates manual-reset (MR), over-temperature, and protection in hot-swap application
2009-04-17 11:27:16529
Network Interface and Circuit
to outgoing telephone lines. Because phone lines can expose circuitry to hazardous overvoltage or overcurrent conditions, protection networks (e
2009-04-20 09:23:391385
积极高压瞬态保护特朗普传统方法在汽车电子领域中的应用-Act
Abstract: Most vehicle electronic systems require overvoltage, reverse-battery, and transient
2009-04-22 09:06:531935
Series Protection for Power-Li
low and high voltages. It includes a high-side switch-driver IC and fast-response, 3-transistor, overvoltage detector. Vo
2009-04-29 10:42:46855
使用MAX8515并联稳压器输出电压感测应用的DC - DC
Abstract: Output overvoltage protection is a critical feature for DC-DC converters in order
2009-04-29 10:57:191714
过电压保护汽车系统-Overvoltage Protecti
Abstract: Vehicle electronics system components such as sensors and actuators require protection
2009-04-29 11:04:051033
Active High-Voltage Transient
2009-05-02 10:33:381432
2009-05-04 09:37:04666
Avoid overvoltage stresses by
Avoid overvoltage stresses by minimizing power-supply pumping on single-ended output, Class D audio
2010-04-18 12:59:001005
Automotive protection circuit
voltage, and includes a low-current overvoltage-protection IC (MAX6495
2011-01-02 13:40:141390
MAX14606,MAX14607 pdf datasheet
The MAX14606/MAX14607 overvoltage protection devices feature low 54m (typ) on-resistance (RON
2012-01-23 09:27:5532
Auto_CAD安装向导
Auto_CAD安装向导
2013-03-07 14:38:100
Solutions for LED Driver Overvoltage Protection
2013-06-17 21:40:1810
欢迎下载AUTO CAD 2008注册机
电子发烧友网站提供《欢迎下载AUTO CAD 2008注册机.rar》资料免费下载
2014-07-22 09:42:1120
PCB_Auto-Routing设计
PCB Auto-Routing设计注意:用AD10绘制的图,低于AD10的版本无法打开。
2016-01-11 11:28:550
PCB_Auto-Routing设计
PCB Auto-Routing设计喜欢的朋友下载来学习
2016-02-17 14:29:310
auto_TFT_display
auto_TFT_display,有需要的下来看看。
2016-02-22 15:48:0614
Linux系统之chardev_early_auto_mknod
Linux系统之chardev_early_auto_mknode教程,很好的DSP自学资料,快来学习吧。
2016-04-15 17:49:5310
谷歌推出独立的Android Auto应用 与苹果CarPlay相似
谷歌在开发名为Android Auto、与苹果CarPlay相似的产品。当前版本的Android Auto要求Android智能手机与车载信息娱乐系统相连。谷歌今年11月正式宣布推出独立的Android Auto应用,帮助更多的用户实现体验Android Auto的愿望。
2016-12-23 11:01:031787
Protection Schemes for BI-FET Am
Protection Schemes for BI-FET Amplifiers and Switches
2017-03-24 15:12:210
What is a TSPD?
The TSPD or Thyristor Surge Protection Device are specialized silicon based overvoltage protectors
2017-04-11 10:13:2932
viper17节能反激式高压开关稳压器转换器数据表
of overcurrent protectionovervoltage and overload protections, hysteresis thermal protection
2017-09-25 13:32:1921
viper27离线式高压变频器
of over-current protectionovervoltage and overload protections, hysteretic thermal protection
2017-09-25 13:36:4331
viper37固定频率的离线转换器数据表
This device is an offline converter with an 800 V rugged power section, a PWM control, two levels of overcurrent protectionovervoltage and overload protection
2017-09-25 13:46:256
如何使用MAX171761增加过电压和过电流保护(1)
Sean demonstrates how the MAX17561 adds overvoltage protection using the MAX17561EVKIT. To learn
2018-10-11 03:43:003524
宝马支持无线Android Auto,将在2020年7月开始集成配备
12月12日消息,宝马终于宣布,将在2020年7月开始将Android Auto集成到其汽车中,而且是无线Android Auto,这使宝马成为少数几个提供无线Android Auto的汽车制造商之一。
2019-12-12 14:14:282866
三星透露 SmartThings 将登陆 Android Auto
将登陆 Android Auto。 日前,Android 版 SmartThings 应用已经具备对 Android Auto 的支持,Galaxy S21 系列机型将能够运行这一功能。 三星介绍
2021-01-19 15:18:511832
LTC4367: 100V Overvoltage, Undervoltage and Reverse Supply Protection Controller Data Sheet
2021-01-29 09:16:079
LTC3897 Demo Circuit - 2-Phase Synchronous Boost Converter with Surge Protection and Reverse Protection (16-55V to 48V @ 4A)
2021-02-20 15:52:3310
An Auto mated Parking Guidance System for Megacit
An Auto mated Parking Guidance System for Megacit(电磁炉加热无18V电源)-该文档为An Auto mated Parking Guidance System for Megacit详述资料,讲解的还不错,感兴趣的可以下载看看…………………………
2021-07-26 10:40:3613
Cortex-M4 存储模型(Memory Model)与MPU(Memory Protection Unit)
2021-12-04 13:21:0912
使用Bolt的Auto9matic警报
电子发烧友网站提供《使用Bolt的Auto9matic警报.zip》资料免费下载
2022-11-25 09:28:100
ARM AUTO系统开源
电子发烧友网站提供《ARM AUTO系统开源.zip》资料免费下载
2023-01-05 11:06:210
Auto GPT横空出世,力推算力设施
Auto GPT 区别于传统 GPT,可在没有任何用户指导的情况下搜索互联网和执行保存文件等操作的能力: 如下图所示,Auto GTP 在 GitHub 上的展示任务为为即将到来的复活节等活动发现和生成独特的原始食谱,Auto GPT 在没有任何用户指导的情况下自动生成内容并保存文件。
2023-04-18 10:07:04690
MAX16171: Ideal Diode Controller with Reverse-Current Protection Data Sheet MAX16171: Ideal Diode Controller with Reverse-Current Protection
电子发烧友网为你提供ADI(ADI)MAX16171: Ideal Diode Controller with Reverse-Current Protection Data Sheet相关产品参数
2023-10-17 18:47:52
Auto-py-to-exe:将Python脚本转为Exe的流程
Auto-py-to-exe 能够基于简单的GUI图形界面和Python中的 PyInstaller,将.py转换为.exe,非常容易使用,适合那些需要在windows上直接执行py文件但又
2023-10-31 11:02:58397
已全部加载完成
