优势和特点
5 V Stereo Audio System with 3.3 V Tolerant Digital Interface
Supports 96 kHz Sample Rates on 6 Channels and 192 kHz on 2 Channels
Supports 16-/20-/24-Bit Word Lengths
Multibit Σ-Δ Modulators with Perfect Differential Linearity Restoration for Reduced Idle Tones and Noise Floor
Data Directed Scrambling DACs—Least Sensitive to Jitter
Differential Output for Optimum Performance
DACs Signal-to-Noise and Dynamic Range: 110 dB –94 dB THD + N—6-Channel Mode –95 dB
On-Chip Volume Control per Channel with 1024-Step Linear Scale
Software Controllable Clickless Mute
Digital De-emphasis Processing
Supports 256 fS, 512 fS, and 768 fS Master Clock Modes
Power-Down Mode Plus Soft Power-Down Mode
Flexible Serial Data Port with Right-Justified, Left-Justified, I2S Compatible, and DSP Serial Port Modes
Supports Packed Data Mode and TDM Mode 48-Lead LQFP Plastic Package A
产品详情
AD1833是一款完整的高性能、单芯片、多通道、数字音频回放系统。它内置6个音频回放通道,每个通道均含有高性能数字插值滤波器、采用ADI专利技术的多位Σ-Δ调制器以及连续时间电流输出模拟DAC部分。其它特性包括片内免点击衰减器,以及通过SPI兼容型串行控制端口编程实现各通道独立静音功能。
