AD5246 采用SC70封装的128位I2C兼容可编程电阻
数据:
产品信息
优势和特点
128 Position
End-to-End Resistance 5kΩ, 10kΩ , 50kΩ , 100kΩ
Ultra-Compact SC70-6 (2 mm x 2.1 mm) Package
I2C Compatible Interface
Full Read/Write of Wiper Register
Power-on Preset to Midscale
Single Supply +2.7 V to +5.5 V
Low Temperature Coefficient 45 ppm/°C
Low Power, IDD=3 µA typical
Wide Operating Temperature –40°C to +125°C
Evaluation Board Available
Available in lead-free (Pb-free) package
产品详情
The AD5246 provides a compact 2 mm × 2.1 mm packaged solution for 128-position adjustment applications. This device performs the same electronic adjustment function as a variable resistor. Available in four different end-to-end resistance values (5 kΩ, 10 kΩ, 50 kΩ, 100 kΩ), these low temperature coefficient devices are ideal for high accuracy and stability variable resistance adjustments.
The wiper settings are controllable through the I2C compatible digital interface, which can also be used to read back the present wiper register control word. The resistance between the wiper and either end point of the fixed resistor varies linearly with respect to the digital code transferred into the RDAC1 latch.
Operating from a 2.7 V to 5.5 V power supply and consuming 3 μA allows for usage in portable battery-operated applications.
APPLICATIONS
Mechanical potentiometer replacement in new designs
Transducer adjustment of pressure, temperature, position,chemical, and optical sensors
RF amplifier biasing
Automotive electronics adjustment
Gain control and offset adjustment
1The terms digital potentiometer, VR, and RDAC are used interchangeably in this document.
技术文档
数据手册(1)
元器件购买 AD5246 相关库存
相关阅读
