BQ27010 单节锂电池和锂聚合物电池电量监测计 IC
数据:
产品信息
描述The bqJUNIOR™ series are highly accurate stand-alone single-cell Li-Ion and Li-Pol battery capacity monitoring and reporting devices targeted at space-limited, portable applications. The IC monitors a voltage drop across a small current sense resistor connected in series with the battery to determine charge and discharge activity of the battery. Compensations for battery age, temperature, self-discharge, and discharge rate are applied to the capacity measurments to provide available time-to-emptyinformation across a wide range of operating conditions. Battery capacity is automatically recalibrated, or learned, in the course of a discharge cycle from full to empty. Internal registers include current, capacity, time-to-empty, state-of-charge, cell temperature and voltage, status, and more.The bqJUNIOR can operate directly from single-cell Li-Ion and Li-Pol batteries and communicates to the system over a HDQ one-wire or I2C serial interface.特性HDQ (bq27010) or I2C (bq27210) CommunicationReports Accurate Time-to-Empty At Both Measured and Host-Requested Load ValuesReports Available Capacity Compensated for Discharge Rate, Temperature, and AgeEnd-of-Discharge Voltage Compensated for Discharge Rate and TemperatureAutomatic Capacity Reduction with AgeReports Temperature, Voltage, and CurrentHigh Accuracy Charge and Discharge Current Integration with Automatic Offset Calibration Requires No User CalibrationProgrammable Input/Output PortInternal User EEPROM Configuration MemoryUploadable Coefficients Allows Host-Side Use with Multiple Pack CharacteristicsStable Oscillator Without External ComponentsDynamic End-of-Discharge Detection Delay to Allow Use in a High-Dynamic Load EnvironmentAutomatic Sleep Mode When Communication Lines are LowAvailable in a Small 3 mm x 4 mm QFN PackageFive Low-Power Operating ModesActive:< 90 µASleep: < 2.5 µAShip: < 2 µA (bq27010 only)Hibernate: < 1.5 µAData Retention:< 20 nAAPPLICATIONSPDASmart PhonesMP3 PlayersDigital CamerasInternet AppliancesHandheld DevicesbqJUNIOR is a trademark of Texas Instruments.
技术文档
数据手册(1) 相关资料(9)
元器件购买 BQ27010 相关库存
相关阅读
