产品频道
BQ3060 符合 SBS 1.1 的电量监测计和保护器
数据: BQ3060中文资料.pdf
产品信息
描述 The Texas Instruments bq3060 Battery Manager is a fully integrated, single-chip, pack-based solution that provides a rich array of features for gas gauging, protection, and authentication for 2, 3, or 4 series cell Li-Ion battery packs. With a footprint of merely 7.8 mm × 6.4 mm in a compact 24-pin TSSOP package, the bq3060 maximizes functionality and safety while dramatically cutting the solution cost and size for smart batteries. Using its integrated high-performance analog peripherals, the bq3060 measures and maintains an accurate record of available capacity, voltage, current, temperature, and other critical parameters in Li-Ion or Li-Polymer batteries, and reports the information to the system host controller over an SMBus 1.1-compatible interface.The bq3060 provides software-first level and second level safety protection on overvoltage, undervoltage, overtemperature, and overcharge, as well as hardware-overcurrent in discharge, short circuit in charge, and discharge protection.特性 Advanced CEDV (Compensated End-of-Discharge Voltage) Gauging Fully Integrated 2, 3, and 4 Series Li-Ion or Li-Polymer Cell Battery Pack Manager 8-Bit RISC CPU With Ultra-Low Power Modes Full Array of Programmable Protection FeaturesVoltage, Current, and TemperatureSHA-1 Authentication Flexible Memory Architecture With Integrated Flash Memory Supports Two-Wire SMBus v1.1 Interface With High-speed 400kHz Programming Option P-CH High Side Protection FET Drive Low Power Consumption Sleep Mode: < 69 µA High-Accuracy Analog Front End With Two Independent ADCs High-Resolution, 15~22-bit Integrator for Coulomb Counting16-Bit Delta-Sigma ADC With a 16-Channel Multiplexer for Voltage, Current, and Temperature Ultra Compact Package: 24-Pin TSSOP PWAll trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(5)
元器件购买 BQ3060 相关库存
相关阅读
