产品信息
描述 The TPD2E001 is a two-channel Transient Voltage Suppressor (TVS) based Electrostatic Discharge (ESD) protection diode array. The TPD2E001 is rated to dissipate ESD strikes at the maximum level specified in the IEC 61000-4-2 Level 4 international standard.The DRS package (3.00 mm × 3.00 mm) is also available as a non-magnetic package for medical imaging applications.See also TPD2E2U06DRLR which is p2p compatible to TPD2E001DRLR and offers higher IEC ESD Protection, lower clamping voltage, and eliminates the input capacitor requirement.特性IEC 61000-4-2 ESD Protection (Level 4) ±8-kV Contact Discharge ±15-kV Air-Gap Discharge IO Capacitance: 1.5 pF (Typ) Low Leakage Current: 1 nA (Maximum) Low Supply Current: 1 nA 0.9 V to 5.5 V Supply-Voltage Range Space-Saving DRL, DRY, and QFN Package Options Alternate 3, 4, 6-Channel options Available: TPD3E001, TPD4E001, TPD6E001
电路图、引脚图和封装图
