产品频道
TLC59582 48 通道、16 位 ES-PWM LED 驱动器,具有预充电 FET、LOD Caterpillar 和
数据: TLC59582中文资料.pdf
产品信息
描述The TLC59581/82are 48-channel constant-current sink drivers. Each channel has an individually-adjustable, 65536-step, pulse width modulation (PWM) grayscale (GS) brightness control.The TLC59581 can support 32-multiplexing while TLC59582 can support 16-multiplexing.The output channels are divided into three groups. Each group has a 512-step color brightness control (CC). CC adjusts brightness control between colors. The maximum current value of all 48 channels can be set by 8-step global brightness control (BC). BC adjusts brightness deviation between LED drivers. GS, CC and BC data are accessible through a serial interface port.See application note Build High Density, High Refresh Rate, Multiplexing LED Panel with TLC59581, SLVA744. The TLC59581/82 device has one error flag: the LED open detection (LOD), which can be read through a serial interface port. To resolve this caterpillar issue caused by an open LED, the TLC59581/82 device has an enhanced circuit for caterpillar canceling, thermal shut down (TSD) and IREF resistor short protection (ISP), which ensures a higher system reliability. The TLC59581/82 device also has a power-save mode that sets the total current consumption to 0.8 mA (typical) when all outputs are off. The TLC59581/82 device is a good solution to improve display performance of a multiplexing panel for low-grayscale patterns.特性 48 Constant-Current Sink Output Channels Sink Current Capability with Max BC/CC data:25 mA at 5 VCC 20 mA at 3.3 VCC Global Brightness Control (BC): 3-Bit (8-Step) Color Brightness Control (CC) for Each Color Group: 9-Bit (512-Step), Three Groups LED Power Supply Voltage Up To 10 V VCC = 3.0 V to 5.5 V Constant Current Accuracy Channel-to-Channel = ±1%(Typ), ±3%(Max) Device-to-Device = ±1%(Typ), ±2%(Max) Data Transfer Rate: 25 MHz Gray Scale Clock: 33 MHz Pre-Charge FET to Avoid Ghosting Phenomenon Enhanced Circuit for Caterpillar Cancelling Low-Grayscale Enhancement LED Open Detection (LOD) Thermal Shut Down (TSD) Operating Temperature: –40°C to 85°C
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(1)
元器件购买 TLC59582 相关库存
相关阅读
