产品频道
TLV1572 10 位 1.25 MSPS ADC 单通道 DSP/(Q)SPI IF S 极低功耗自动断电功能
数据: TLV1572中文资料.pdf
产品信息
描述The TLV1572 is a high-speed 10-bit successive-approximation analog-to-digital converter (ADC) that operates from a single 2.7-V to 5.5-V power supply and is housed in a small 8-pin SOIC package.The TLV1572 accepts an analog input range from 0 to VCC and digitizes the input at a maximum 1.25 MSPS throughput rate. The power dissipation is only 8 mW with a 3-V supply or 25 mW with a 5-V supply. The device features an auto-powerdown mode that automatically powers down to 10 uA whenever a conversion is not performed. The TLV1572 communicates with digital microprocessors via a simple 3- or 4-wire serial port that interfaces directly to the Texas Instruments TMS320 DSPs and (Q)SPI compatible microcontrollers without using additional glue logic. Very high throughput rate, simple serial interface, SO-8 package, 3-V operation, and low power consumption make the TLV1572 an ideal choice for compact or remote high-speed systems.特性Fast Throughput Rate: 1.25 MSPS 8-Pin SOIC Package Differential Nonlinearity Error: < ±1 LSB Integral Nonlinearity Error: < ±1LSB Signal-to-Noise and Distortion Ratio: 59 dB, f(input) = 500 kHz Single 3-V to 5-V Supply Operation Very Low Power: 8 mW at 3V; 25mW at 5 V Auto-Powerdown: 10 uA Maximum Glueless Serial Interface to TMS320 DSPs and (Q)SPI Compatible Micro-Controllers Inherent Internal Sample and Hold Operation
技术文档
数据手册(1) 相关资料(1)
元器件购买 TLV1572 相关库存
