LM324-MIL 四路运算放大器
数据:
产品信息
描述This device consist of four independent high-gain frequency-compensated operationalamplifiers that are designed specifically to operate from a single supply or split supply over awide range of voltages.特性Wide Supply RangesSingle Supply: 3 V to 32 VDual Supplies: ±1.5 V to ±16 VLow Supply-Current Drain Independent ofSupply Voltage: 0.8 mA Typical Common-Mode Input Voltage RangeIncludes Ground, Allowing Direct Sensing Near GroundLow Input Bias and OffsetParametersInput Offset Voltage: 3 mV Typical Input Offset Current: 2 nA TypicalInput Bias Current: 20nA Typical Differential Input Voltage Range Equal toMaximum-Rated Supply Voltage: 32 VOpen-Loop Differential Voltage Amplification:100 V/mV Typical Internal FrequencyCompensationOn Products Compliant to MIL-PRF-38535, All Parameters are Tested Unless Otherwise Noted. On All Other Products, ProductionProcessing Does Not Necessarily Include Testing of All Parameters.All trademarks are the property of their respective owners.
技术文档
数据手册(1) 相关资料(8)
元器件购买 LM324-MIL 相关库存
相关阅读
