I 2 C串行总线接口兼容性,支持标准模式,100 kbits /s和快速模式,400 kbits /s
关断模式以最大限度地降低功耗
可编程 RST_OUT / OS 引脚: RST_OUT 提供复位输出; OS 提供由过温关闭事件激活的中断输出
软件和引脚与LM80兼容
Key Specifications
Total Unadjusted Error ±1 %FS (Max)
Differential Non-Linearity ±1 Lsb (Max)
Supply Voltage Range +3.0 V to +5.5 V
Supply Current (Operating) 0.370 mA Typ
Supply Current (Shutdown) 0.330 mA Typ
ADC Resolution 10 Bits
Temperature Resolution 0.5°C/0.0625°C
Temperature Accuracy ±3°C (Max)
All trademarks are the property of their respective owners.
参数 与其它产品相比 数字温度传感器
Device type Interface Local sensor accuracy (Max) (+/- C) Temp Resolution (Max) (bits) Operating temperature range (C) Supply Voltage (Min) (V) Supply Voltage (Max) (V) Supply Current (Max) (uA) Remote channels (#) Addresses Rating Package Group Package size: mm2:W x L (PKG) LM96080 Fan Controller I2C, SMBus 2 12 -40 to 125 3 5.5 580 0 8 Catalog TSSOP | 24 24TSSOP: 50 mm2: 6.4 x 7.8 (TSSOP | 24)
