DP83867器件是一款稳健耐用型低功耗全功能物理层收发器,它集成了PMD子层以支持10BASE-Te,100BASE- TX和1000BASE-T以太网协议.DP83867经优化可提供ESD保护,超过了8kV IEC 61000-4-2标准(直接接触)。
DP83867可轻松实现10/100 /1000Mbps以太网LAN。它通过外部变压器直接连接双绞线介质。此器件通过RGMII或嵌入式时钟SGMII直接与MAC层相连。
DP83867提供精确时钟同步,其中包括同步以太网时钟输出。器件具有低延迟,并提供IEEE 1588帧起始检测。
DP83867采用低功耗设计,满功率运行时消耗457mW。局域网唤醒可用于降低系统功耗。
< /DIV>
所有商标均为其各自所有者的财产。
Function |
Port Count |
Datarate (Mbps) |
Interface |
Supply Voltage (Volt) |
Cable Length (m) |
JTAG1149.1 |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
DP83867E | DP83867CR | DP83867CS | DP83867IR | DP83867IS |
PHY | PHY | PHY | PHY | PHY |
Single | Single | Single | Single | Single |
10/100/1000 | 10/100/1000 | 10/100/1000 | 10/100/1000 | 10/100/1000 |
RGMII SGMII | RGMII | RGMII SGMII | GMII RGMII MII | RGMII SGMII |
1 2.5 | 1 2.5 | 1 2.5 | 1.1 2.5 | 1 2.5 |
130 | 130 | 130 | 130 | 130 |
Yes | Yes | Yes | Yes | Yes |
Cable Diagnostics IEEE 1588 SOF | Cable Diagnostics IEEE 1588 SOF | Cable Diagnostics IEEE 1588 SOF | Cable Diagnostics IEEE 1588 SOF | Cable Diagnostics IEEE 1588 SOF |
Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 105 | 0 to 70 | 0 to 70 | -40 to 85 | -40 to 85 |
VQFN | VQFN | VQFN | HTQFP VQFN | VQFN |
48VQFN: 49 mm2: 7 x 7(VQFN) | 48VQFN: 49 mm2: 7 x 7(VQFN) | 48VQFN: 49 mm2: 7 x 7(VQFN) | 64HTQFP: 144 mm2: 12 x 12(HTQFP) 48VQFN: 49 mm2: 7 x 7(VQFN) | 48VQFN: 49 mm2: 7 x 7(VQFN) |
48VQFN | 48VQFN | 48VQFN | 48VQFN 64HTQFP | 48VQFN |
