TUSB1002是业内首款双通道USB 3.1超高速+(SSP)转接驱动器和信号调节器。该器件采用超低功耗架构,由3.3V电源供电运行时的功耗非常低。它支持USB3.1低功耗模式,可进一步降低空闲状态下的功耗。
TUSB1002实现了一款线性均衡器,最高可容许码间串扰(ISI)引入16dB的损耗。当USB信号在印刷电路板(PCB)或电缆上传输时,其完整性会在通道损耗和码间串扰的影响下有所降低。线性均衡器可对通道损失进行补偿,进而延长通道传输距离,从而使系统符合USB规范。凭借双通道和小型封装,TUSB1002可在USB3.1传输路径中灵活放置。
TUSB1002采用24引脚4mm x 4mm VQFN封装。此外,这款产品还提供商业级(TUSB1002)和工业级(TUSB1002I)两个版本。
所有商标均为各自所有者的财产。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TUSB1002 | TUSB1002A | TUSB501 | TUSB501-Q1 | TUSB522P | TUSB551 |
Redriver | Redriver | Redriver | Redriver | Redriver | Redriver |
2 | 2 | 1 | 1 | 2 | 1 |
Dual-channel, Dual-lane | Dual-channel, Dual-lane | Single-channel | Single-channel | Dual-channel, Sigle-lane | Single-channel |
3 | 3 | 3 | 3 | 3 | 1.62 |
3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 1.98 |
NA | NA | NA | NA | NA | |
0 | -0.5 | 0.1 | 0.1 | 0.1 | 0 |
1.7 | 4 | 1.2 | 1.2 | 1.2 | 1.2 |
103mA | 100mA | 65mA | 65mA | 98mA | 82mA |
5000 | 5000 | 2500 | 2500 | 2500 | 2500 |
6 | 5 | 5 | 5 | 4 | |
Ultra-low-power architecture | Ultra-low-power architecture | Aggressive Low-Power Architecture | Aggressive Low-Power Architecture | Ultra low-power architecture | 1.8V power Supply |
Catalog | Catalog | Catalog | Automotive | Catalog | Catalog |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 | -40 to 105 | -40 to 85 0 to 70 | -40 to 85 |
VQFN | VQFN | WSON | WSON | VQFN | X2QFN |
24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | See datasheet (WSON) | See datasheet (WSON) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 12X2QFN: 3 mm2: 1.6 x 1.6(X2QFN) |
24VQFN | 24VQFN | 8WSON | 8WSON | 24VQFN | 12X2QFN |
