UCC27611是一款针对5V驱动而进行优化的单通道,高速,栅极驱动器,它专门用来对增强模式GaN FET进行寻址。驱动电压VREF被内部线性稳压器精确稳压至5V.UCC27611提供4A拉电流和6A灌电流的非对称轨到轨峰值电流驱动能力。凭借分离输出配置,可根据FET优化其导通和关断时间。具有最低寄生电感的封装和引脚分配减少了上升和下降时间并限制了振铃。此外,具有最小容差和变化的短传播延迟可实现高频时的有效运行.1Ω和0.35Ω电阻提升了针对高转换率dV和dt所致硬开关的抗扰度。
不受VDD输入信号阈值的影响确保了TTL和CMOS低压逻辑兼容性。出于安全方面的考虑,当输入引脚处于悬空状态时,内部输出上拉和下拉电阻将输出保持在低电平.VREF引脚上的内部电路具有欠压锁定功能,可在VREF电源电压处于工作围内之前,将输出保持在低电平.UCC27611采用具有外部散热焊盘和接地焊盘的小型2.00mm×2.00mm SON-6封装(DRV),提升了封装功率处理能力.UCC27611运行在-40 °C至140°C的宽温度范围内。
所有商标均为其各自所有者的财产。
Number of Channels (#) |
Power Switch |
Peak Output Current (A) |
Input VCC (Min) (V) |
Input VCC (Max) (V) |
Rise Time (ns) |
Fall Time (ns) |
Prop Delay (ns) |
Input Threshold |
Channel Input Logic |
Input Negative Voltage (V) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
UCC27611 | LM5114 | UCC27511 | UCC27511A | UCC27512 | UCC27517 |
1 | 1 | 1 | 1 | 1 | 1 |
MOSFET GaNFET | MOSFET GaNFET | MOSFET IGBT GaNFET | MOSFET IGBT GaNFET | MOSFET IGBT GaNFET | MOSFET IGBT GaNFET |
6 | 7.6 | 8 | 8 | 8 | 4 |
4 | 4 | 4.5 | 4.5 | 4.5 | 4.5 |
18 | 12.6 | 18 | 18 | 18 | 18 |
9 | 12 | 9 | 9 | 9 | 9 |
4 | 3 | 7 | 7 | 7 | 7 |
14 | 12 | 13 | 13 | 13 | 13 |
CMOS TTL | CMOS TTL | CMOS TTL | CMOS TTL | CMOS TTL | CMOS TTL |
Inverting Non-Inverting | Inverting Non-Inverting | Inverting Non-Inverting | Inverting Non-Inverting | Inverting Non-Inverting | Inverting Non-Inverting |
0 | 0 | 0 | -5 | 0 | 0 |
Split Output | Controllable Rise and Fall Times | Split Output | Split Output | Hysteretic Logic | Hysteretic Logic |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 140 | -40 to 125 | -40 to 140 | -40 to 140 | -40 to 140 | -40 to 140 |
WSON | SOT-23 WSON | SOT-23 | SOT-23 | SON | SOT-23 |
