CC2592器件是一款针对低功率和低压2.4GHz无线应用的经济高效且高性能的RF前端。
CC2592器件是一款针对德州仪器(TI)所有CC25XX 2.4GHz低功率RF收发器,发射器和片上系统产品的范围扩展器。
为了增加链路预算,CC2592器件提供一个可增加输出功率的功率放大器,以及一个具有低噪声系数的LNA,以提升接收器灵敏度。
CC2592器件提供一个极小尺寸,高输出功率RF设计,此设计采用4mm x 4mm四方扁平无引线(QFN)-16封装。
CC2592器件包含高性能无线应用简单设计所需的PA,LNA,开关,RF匹配和不平衡变压器。
Device Type |
Frequency (MHz) |
Flash (KB) |
RAM |
Security |
Over-the-air Upgrade |
Peripherals |
Timers - 16-bit |
Timers - 32-bit |
GPIO |
ADC |
RX Current (Lowest) (mA) |
Sleep Current (uA) |
Output Power (dBm) |
RX Sensitivity (dBm) |
Data Rate (Max) (kbps) |
Operating Temperature Range (C) |
Package Group |
Key Applications |
Technology |
CC2592 | CC2590 |
Range Extender | Range Extender |
2400 | 2400 |
N/A | 0 |
N/A | N/A |
N/A | N/A |
No | N/A |
N/A | N/A |
0 | 0 |
0 | 0 |
0 | 0 |
N/A | N/A |
1.9 | 1.8 |
0.1 | 0.1 |
22 | 14 |
Typical 3 dB improvement | Typical 3 dB improvement |
500 2000 | |
-40 to 125 | -40 to 85 |
VQFN | VQFN |
N/A | N/A |
2.4 GHz | Proprietary 2.4 GHz |
