数据: LM71/LM71Q SPI/MICROWIRE 13-Bit Plus Sign Temperature Sensor 数据表
The LM71 is a low-power, high-resolution digital temperature sensor with an SPI and MICROWIRE compatible interface, available in the 5-pin SOT-23 or the 6-pin WSON (no pull back) package. The host can query the LM71 at any time to read temperature. Its low operating current is useful in systems where low power consumption is critical.
The LM71 has 13-bit plus sign temperature resolution (0.03125°C per LSB) while operating over a temperature range of −40°C to +150°C.
The LM71’s 2.65V to 5.5V supply voltage range, fast conversion rate, low supply current, and simple SPI interface make it ideal for a wide range of applications. The LM71Q is available in the 5-lead SOT-23 package only.
所有商标均为其各自所有者的财产。
Interface |
Local Sensor Accuracy (Max) (+/- C) |
Temp Resolution (Max) (bits) |
Operating Temperature Range (C) |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
Addresses |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Iq (Typ) (uA) |
LM71-Q1 | LM71 | LM73 |
SPI, Microwire | SPI, Microwire | I2C, SMBus, 2-Wire |
1.5 | 1.5 | 1 |
14 | 14 | 14 |
-40 to 150 | -40 to 150 | -40 to 150 |
2.65 | 2.65 | 2.7 |
5.5 | 5.5 | 5.5 |
300 | 300 | 320 |
550 | 550 | 550 |
Shutdown | Shutdown |
Configurable Resolution Programmable Alert One-Shot Conversion Shutdown UL Recognized |
NA | NA | 6 |
Automotive | Catalog | Catalog |
SOT-23 |
SOT-23 WSON |
SOT-23-THIN |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) See datasheet (WSON) |
6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) |
300 | 300 | 320 |
