数据: LM84 Diode Input Digital Temperature Sensor with Two-Wire Interface 数据表
LM84是一款远程二极管温度传感器,Delta-Sigma模数转换器,以及带SMBus的数字过温检测器?接口。 LM84可感应其自身的温度以及具有二极管结的目标IC的温度,例如Pentium®II处理器或连接2N3904的二极管。目标IC的芯片需要二极管结(半导体结)。主机可以随时查询LM84,以读取该二极管的温度以及LM84本身的温度状态。当温度高于可编程比较器限值T_CRIT时,T_CRIT_A#中断输出变为有效。
主机可以编程以及回读T_CRIT寄存器的状态。三个状态逻辑输入允许两个引脚(ADD0,ADD1)为LM84选择多达9个SMBus地址位置。对于T_CRIT,传感器的默认阈值为127°C。
电源电压 | 3.0V - 3.6V |
电源电流 | 1 mA(最大值) |
局部温度精度 | ±1.0°C(典型值) |
远程二极管温度精度 | |
+ 60°C至+ 100°C | ±3°C(最大值) |
0 °C至+ 125°C | ±5°C(最大值) |
Interface |
Local Sensor Accuracy (Max) (+/- C) |
Temp Resolution (Max) (bits) |
Operating Temperature Range (C) |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Iq (Typ) (uA) |
LM84 | LM95213 | LM95214 | LM95233 | LM95234 | LM95235 | LM95235-Q1 |
I2C SMBus |
I2C SMBus |
I2C SMBus |
I2C SMBus |
I2C SMBus |
I2C SMBus |
I2C SMBus |
1 | 2 | 2 | 2 | 2 | 2 | 2 |
8 | 11 | 11 | 11 | 11 | 11 | 11 |
0 to 125 | -40 to 140 | -40 to 140 | -40 to 140 | -40 to 140 |
-40 to 90 0 to 90 |
-40 to 85 |
3 | 3 | 3 | 3 | 2.7 | 3 | 2.7 |
3.6 | 3.6 | 3.6 | 3.6 | 5.5 | 5.5 | 5.5 |
500 | 570 | 570 | 570 | 570 | 350 | 350 |
1000 | 800 | 800 | 500 | 800 | 650 | 350 |
Programmable Alert Remote diode fault detection |
One shot conversion control Programmable Alert Programmable conversion rate Remote diode fault detection Shutdown Thermal diode input stage filtering |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Automotive |
SSOP | WSON | WSON | WSON | WSON | VSSOP | VSSOP |
16SSOP: 29 mm2: 6 x 4.9(SSOP) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
