TS3L500是一个16位至8位多路复用器/多路分解器LAN开关,具有单选(SEL)输入。 SEL控制多路复用器/多路分解器的数据路径。该器件提供额外的I /O,用于指示LED信号的开关状态。
器件提供低且平坦的导通电阻(r on )和出色的导通电阻比赛。低输入/输出电容,高带宽,低偏斜和通道间低串扰使该器件适用于各种LAN应用,例如10/100/1000 Base-T。
此器件可用于在LAN应用中更换机械继电器。它还可用于将信号从10/100 Base-T以太网收发器路由到笔记本电脑或扩展坞中的RJ-45 LAN连接器。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Crosstalk (dB) |
ESD Charged Device Model (kV) |
ICC (Typ) (uA) |
Input/Output Continuous Current (Max) (mA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
Off Isolation (Typ) (dB) |
Propagation Delay (ns) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
RON Flatness (Typ) (Ohms) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
VIH (Min) (V) |
VIL (Max) (V) |
TS3L500 |
10 BASE-T 100 BASE-T 1000 BASE-T LVDS LAN |
2:1 SPDT |
11 |
3 |
3.6 |
4 |
0 |
5.5 |
500 |
1100 |
2 |
-40 to 85 |
56WQFN: 55 mm2: 5 x 11(WQFN) |
WQFN |
-37 |
1 |
250 |
128 |
2.5 |
8 |
-37 |
0.25 |
6 |
1 |
0.5 |
9 |
15 |
2 |
0.8 |
