数据: Quadruple 2-Line to 1-Line Data Selector/Multiplexer 数据表
SN74LVC157A四路2线至1线数据选择器/多路复用器设计用于2.7 V至3.6 VV CC 操作。
该设备具有一个共同的选通( G )输入。当 G 为高时,所有输出都为低。当 G 为低电平时,从两个源中选择一个4位字,并将其路由到四个输出。该器件提供真实数据。
输入可以从3.3 V或5 V器件驱动。此功能允许在混合的3.3 V /5 V系统环境中将此设备用作转换器。
Function |
Technology Family |
VCC (Min) (V) |
VCC (Max) (V) |
Channels (#) |
Voltage (Nom) (V) |
F @ Nom Voltage (Max) (Mhz) |
ICC @ Nom Voltage (Max) (mA) |
tpd @ Nom Voltage (Max) (ns) |
Configuration |
Type |
IOL (Max) (mA) |
IOH (Max) (mA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Bits (#) |
Digital input leakage (Max) (uA) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
SN74LVC157A-Q1 | SN54LVC157A | SN74LVC157A | SN74LVC157A-EP |
Encoder | Encoder/Multiplexer | Encoder Multiplexer | Encoder/Multiplexer |
LVC | LVC | LVC | LVC |
2 | 2 | 1.65 | 2 |
3.6 | 3.6 | 3.6 | 3.6 |
4 | 4 | 4 | 4 |
2.7 3.3 | 2.7 3.3 | 1.8 2.5 2.7 3.3 | 2.7 3.3 |
100 | 100 | 100 | 100 |
0.01 | 0.01 | 0.04 | 0.01 |
8.2 7 | 6.2 5.4 | 13.5 7.4 5.7 5 | 8.2 7 |
2:01 | 2:1 | 2:1 | 2:1 |
Standard | Standard | Standard | Standard |
24 | 24/-24 | 24 | 24/-24 |
-24 | -24 | ||
Automotive | Military | Catalog | HiRel Enhanced Product |
-40 to 125 | -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 |
SOIC TSSOP | CDIP CFP | SO SOIC SSOP TSSOP VQFN | SOIC TSSOP |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) See datasheet (CFP) | 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 48 mm2: 7.8 x 6.2(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
2 | 2 | 2 | 2 |
5 | 5 | 5 | 5 |
0.75 | 0.75 | 0.75 | 0.75 |
2 | 2 | 2 | 2 |
无样片 |
