TMUX154E是一款高带宽2:1开关,专门针对限制I /O的应用中的高速信号开关进行设计。此开关具有较宽的带宽(900MHz),这一特性使得信号传递具有最少的边缘失真和相位失真。此开关为双向开关,高速信号衰减极少或者没有。它能实现低位间偏移和高通道间噪声隔离。 /p>
TMUX154E在所有引脚上集成了ESD保护单元,采用微型UQFN封装(1.8mm×1.4mm)或VSSOP封装,自然通风条件下的工作温度范围为-40°C至85°C 。
(1) EN 和SEL输入除外
<小> (2)标准HBM测试(A114-B,II类)外部执行了高压HBM测试,仅适用于进行接地测试的I /O端口。
所有商标均为他们各自的所有者。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TMUX154E | TMUX1072 | TMUX136 |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
2 | 2 | 2 |
Single | Single | Single |
N/A | N/A | N/A |
N/A | N/A | N/A |
3 | 2.3 | 2.3 |
4.3 | 5.5 | 4.8 |
6 | 6 | 4.6 |
900 | 1200 | 6100 |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 125 | -40 to 85 |
10UQFN: 3 mm2: 1.4 x 1.8(UQFN) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10UQFN: 3 mm2: 2 x 1.5(UQFN) |
UQFN VSSOP | VSSOP | UQFN |
4.3 | 3.2 | 4.8 |
10 | 15 | 7.5 |
1 | 75 | 30 |
100 | 50 | |
Powered off protection 1.8-V Compatible Control Inputs | Powered off protection 1.8-V Compatible Control Inputs Overvoltage Protection | Powered off protection 1.8-V Compatible Control Inputs |
2 | 10 | |
1 | 2 | |
7.5 | 4.5 | 1.4 |
2 | 4.5 | 1.6 |
1 | 1 | 1 |
8 | 2 | 3.5 |
0.5 | 0.5 | 0.6 |
1.3 | 1.4 | 1.3 |
