TS5A22364-Q1是一款双通道单刀双掷(SPDT)模拟开关,设计用于2.3V至5.5V电源。该器件支持负信号摆幅,允许低于接地电平的信号通过开关,同时不发生失真。此外,TS5A22364-Q1还包含一个内部分流开关,能够在常闭或常开引脚未连接至COM时使其电容放电。此开关可降低在切换电源时出现的喀哒声和噼啪声。先断后合特性可防止信号在跨路径传输时出现失真。该器件同时拥有低导通电阻,出色的通道间导通状态电阻匹配以及最小总谐波失真(THD)性能,是音频应用的理想选择。
所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TS5A22364-Q1 | TS5A22362 | TS5A22364 | TS5A22366 |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
2 | 2 | 2 | 2 |
Single | Single | Single | Single |
N/A | N/A | N/A | N/A |
2.3 | 2.3 | 2.3 | 2.25 |
5.5 | 5.5 | 5.5 | 5.5 |
0.52 | 0.52 | 0.52 | 0.7 |
18.3 | 18.3 | 18.3 | 32 |
Automotive | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 |
10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) 10VSON: 9 mm2: 3 x 3(VSON) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) 10VSON: 9 mm2: 3 x 3(VSON) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) |
VSSOP | DSBGA VSON VSSOP | DSBGA VSON VSSOP | DSBGA |
1.3 | 1.3 | 1.3 | 2 |
150 | 350 | 350 | 150 |
6 | 0.1 | 0.1 | 1 |
14 | 5 | 5 | 10 |
Break-before-make Supports negative voltages | Supports negative voltages | Break-before-make Supports negative voltages Click/Pop Noise Reduction | Break-before-make Supports negative voltages |
0.375 | 0.375 | ||
0.375 | 0.375 | 0.375 | 0.375 |
370 | 370 | 370 | 176 |
70 | 48 | ||
1.5 | 1.5 | 1.5 | 1 |
2.5 | 2.5 | 2.5 | 2.5 |
0.8 | 0.8 | 0.8 | 0.65 |
1.4 | 1.4 | 1.4 | 1.05 |
