数据: Dual 4-to-1 Channel Analog Multiplexer/Demultiplexer 数据表
这款双通道4对1 CMOS模拟多路复用器/多路分解器与4052功能引脚兼容,并具有注入电流效应控制功能。该特性在汽车应用中具有极高的价值,其中超过正常电源电压的电压是常见的。
注入电流效应控制允许禁用的模拟输入通道上的信号超过电源电压而不影响信号。启用模拟通道。这消除了通常用于将模拟通道信号保持在电源电压范围内的外部二极管/电阻网络的需要。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74HC4852-Q1 | SN74HC4852 |
4:1 | 4:1 |
2 | 2 |
Single | Single |
N/A | N/A |
N/A | N/A |
2 | 2 |
6 | 6 |
150 | 150 |
Automotive | Catalog |
-40 to 125 | -40 to 125 -40 to 85 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) |
SOIC TSSOP | PDIP SOIC TSSOP TVSOP |
6 | 6 |
700 | 700 |
25 | 25 |
2 | |
20 | 10 |
4 | 4 |
1 | 1 |
6.7 | 6.7 |
6.7 | 6.7 |
1 | 1 |
2 | 2 |
Vdd*.3 | Vdd*.3 |
Vdd*.7 | Vdd*.7 |
