这款8通道CMOS模拟多路复用器/多路分离器与?? 4051功能引脚兼容,另外还具有极佳的注入电流效应控制功能超出正常电源电压的汽车应用中的值是常见的。
注入电流效应控制允许禁用的模拟输入通道上的信号超过电源电压,而不会影响使能模拟通道的信号。这消除了通常用于将模拟通道信号保持在电源电压范围内的外部二极管/电阻网络的需要。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74HC4851 | SN74HC4851-Q1 |
8:1 | 8:1 |
1 | 1 |
Single | Single |
N/A | N/A |
N/A | N/A |
2 | 2 |
6 | 6 |
150 | 150 |
Catalog | Automotive |
-40 to 125 | -40 to 125 |
See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
PDIP SOIC TSSOP TVSOP | SOIC TSSOP |
6 | 6 |
700 | 700 |
25 | 25 |
2 | 2 |
40 | 10 |
4 | 4 |
1 | 1 |
6.7 | 6.7 |
6.7 | 6.7 |
1 | |
2 | |
Vdd*.3 | Vdd*.3 |
Vdd*.7 | Vdd*.7 |
