TMP708是一款全集成式电阻可编程温度开关,其温度阈值仅由一个外部电阻在整个运行范围内进行设定.TMP708提供一个低电平有效的开漏输出,可由电压介于2.7V至5.5V范围内的电源供电。
温度阈值精度通常为±0.5°C,最大值为±3°C( 60°C至100°C。静态消耗电流的典型值为40μA。可通过选择引脚来确定10°C或者30°C的温度滞后。
TMP708采用5引脚小外形尺寸晶体管(SOT-23)封装。
所有商标均为其各自所有者的财产。
Operating Temperature Range (C) |
Accuracy Over Temp Range (Max) (C) |
Sensor Gain (mV/Deg C) |
SetPoint Value (deg C) |
SetPoint Type |
Output Type |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Comparator Channels (#) |
Features |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Interface |
TMP708 | LM26LV | LM26LV-Q1 | LM56 | LM57 | LM57-Q1 | TMP300 | TMP300-Q1 | TMP708-Q1 | TMP709 | TMP709-Q1 |
-40 to 125 | 0 to 150 | -40 to 150 | -40 to 125 | -50 to 150 | -50 to 125 -50 to 150 -50 to 160 | -40 to 125 | -40 to 125 | 0 to 125 | -40 to 125 | 0 to 125 |
3 | 2.3 | 2.3 | 3 | 1.5 | 1.3 | 2 | 2 | 3 | 3 | 3 |
-5.1 to -12.8 | -5.1 to -12.8 | 6.2 | -5.2 to -12.9 | -5.2 to 12.9 | 10 | 10 | ||||
0 to 125 | Range (0 to 150) 50, 60, 65, 70 75, 80, 85, 90 95, 100, 105, 110 115, 120, 125, 130 135, 140, 145, 150 | Range (0 to 150) 130, 135 | -40 to 125 | -40 to 150 | -40 to 160 | -40 to 125 | -40 to 125 | 0 to 125 | 0 to 125 | 0 to 125 |
Resistor Programmable | Factory Programmed | Factory Programmed | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable |
Open Drain | Open Drain Push Pull | Open Drain Push Pull | Open Drain | Open Drain Push Pull | Open Drain Push Pull | Open Drain | Open Drain | Open Drain | Open Drain | Open Drain |
2.7 | 1.6 | 1.6 | 2.7 | 2.4 | 2.4 | 1.8 | 1.8 | 2.7 | 2.7 | 2.7 |
5.5 | 5.5 | 5.5 | 10 | 5.5 | 5.5 | 18 | 18 | 5.5 | 5.5 | 5.5 |
40 | 8 | 8 | 230 | 24 | 24 | 110 | 110 | 40 | 40 | 40 |
1 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Hysteresis (10°C or 30°C) Pin-Selectable Hysteresis | Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch Trip Test | Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch Trip Test | Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch | Built-in Hysteresis Hysteresis (5°C or 10°C) Temperature Sensor and Switch Trip Test | Built-in Hysteresis Hysteresis (5°C or 10°C) Temperature Sensor and Switch Trip Test | Hysteresis (5°C or 10°C) Pin-Selectable Hysteresis Temperature Sensor and Switch | Hysteresis (5°C or 10°C) Pin-Selectable Hysteresis Temperature Sensor and Switch | Hysteresis (10°C or 30°C) Pin-Selectable Hysteresis | Hysteresis (2°C or 10°C) Pin-Selectable Hysteresis | Hysteresis (2°C or 10°C) Pin-Selectable Hysteresis |
Catalog | Catalog | Automotive | Catalog | Catalog | Automotive | Catalog | Automotive | Automotive | Catalog | Automotive |
SOT-23 | WSON | WSON | SOIC VSSOP | TSSOP WSON | TSSOP | SC70 SOT-23 | SC70 | SOT-23 | SOT-23 | SOT-23 |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (WSON) | See datasheet (WSON) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) See datasheet (WSON) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SC70: 4 mm2: 2.1 x 2(SC70) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
Switch | Analog Output Switch | Analog Output Switch | Analog Output Switch | Analog Output Switch | Analog Output Switch | Analog Output Switch | Analog Output Switch | Switch | Switch | Switch |
