F1激光过程工作故障检测功能-激活F_L_Uebw_Ein
F2送丝机过程工作故障检测功能-激活F_DG_Ueberw
F1和F2配合使用可以实现在焊接过程中开关激光和送丝的作用
F7总的过程焊接质量监控合格-故障提示F_Uebw_iO
F200 送丝机故障$FLAG
机器人在激光焊接时等待的条件:
M30 = E14 & E24 & E644 & E646 & !E516& E1013 & F980 & (F7 + A11)
E646 焊头故障
E644进程激活
F7是焊接过程合格
当F7没有时表示在焊接过程中出现故障,这时机器人会等待F7,$ROB_STOPPED机器人运动轨迹停止变量被激活,使得激光和送丝同时关闭。
USER程序控制 :
外部条件不满足时先关闭再说!
IF $FLAG[F_L_Uebw_Ein] AND $FLAG[F_DG_Ueberw] AND ($OUT[O_L_PStart_S] OR $OUT[O_L_PStart_D]) AND$IN[I_L_Prg_akt] AND $IN[I_L_Bereit] AND $IN[I_L_ist_Ein] AND $ROB_STOPPED AND$OUT[O_R_Auto] AND $TIMER_FLAG[30] AND NOT MIT_Precitec AND NOT$FLAG[F_L_MessPos] THEN
F1$F2激活 E909程序激活 E910激光准备 E911激光启动
$FLAG[F_L_MessPos]=F8
$ROB_STOPPED 机器人—机器人运动轨迹停止
$OUT[O_L_PStart_S]=FALSE A908关闭
$OUT[O_L_PStart_D]=FALSE
Laser_Start_AUS=TRUE
Laser_Sperre=FALSE
Laser_Message(3,#NotifyMsg)
ENDIF
恢复开启激光
IF $FLAG[F_L_Uebw_Ein] AND $FLAG[F_DG_Ueberw] AND Laser_Start_AUS AND NOT$OUT[O_L_PStart_S] AND NOT $OUT[O_L_PStart_D] AND $OUT[O_R_Proz_akt] THEN
IF $OUT[O_R_bewegt] AND Laser_statisch AND$IN[I_ALO_Bereit] AND $IN[I_L_Zugeteil] AND NOT $IN[I_L_Stoerung] AND$IN[I_L_Bereit] AND $IN[I_L_ist_Ein] AND NOT $IN[I_L_Sik_off] THEN
Laser_Start_AUS=FALSE
$OUT[O_L_PStart_S]=TRUE A908启动
ENDIF
IF $OUT[O_R_bewegt] AND Laser_dynamisch AND$IN[I_ALO_Bereit] AND $IN[I_L_Zugeteil] AND NOT $IN[I_L_Stoerung] AND$IN[I_L_Bereit] AND $IN[I_L_ist_Ein] AND NOT $IN[I_L_Sik_off] THEN
$OUT[O_L_PStart_D]=TRUE
ENDIF
ENDIF
所以在这里 F1和F2是必须同时在焊接前激活的,用来实现再焊接时出现故障时报错并停止激光,当激光器或送丝机故障恢复后再开启激光,恢复焊接工作的作用。
F7的作用
$FLAG[F_Uebw_iO]=(TEMP_DG_iO OR NOT$FLAG[F_DG_Ueberw]) AND (TEMP_LASER_iOOR NOT $FLAG[F_L_Uebw_Ein]) AND (TEMP_CL_iO OR NOT $FLAG[F_CL_Ueb_Ein])
F7 总的质量监控合格
TEMP_DG_iO送丝机质量监控合格$FLAG[F_DG_Ueberw] F2激活
TEMP_LASER_iO激光焊监控合格 $FLAG[F_L_Uebw_Ein]F1激活
送丝机质量监控合格
TEMP_DG_iO=$OUT[O_R_Auto] AND$OUT[O_R_PERI_RDY] AND NOT Draht_Sperr2 AND NOT $FLAG[F_DG_F_S_Fl] OR (NOT MIT_DG_Kalt ANDNOT MIT_DG_Heiss)
$FLAG[F_DG_F_S_Fl]F200 送丝故障
激光焊监控合格
TEMP_LASER_iO=$OUT[O_R_Auto] AND$OUT[O_R_PERI_RDY] AND (Temp_Hilf_1 OR $TIMER_FLAG[31]) OR NOT MIT_Laser
Temp_Hilf_1激光焊故障提示
F200送丝故障分析
IF MIT_DG_Heiss AND $FLAG[F_DG_Ueberw] AND $FLAG[F_DG_Sch_Ein] AND$OUT[O_DG_S_Proz] AND $TIMER_FLAG[28] THEN
$FLAG[F_DG_Sch_Ein]=F 197 启动送丝
$FLAG[F_DG_Ueberw]=F2 送丝监控
IF NOT $IN[I_DG_P_aktiv] OR NOT $IN[I_DG_bereit] THEN
E1299送机激活&E1297送丝准备
$FLAG[F_DG_F_S_Fl]=TRUE送丝故障F200
DG_F_Strom = TRUE
ENDIF
IF NOT $IN[I_DG_bereit] THEN
DG_F_Bereit = TRUE
ENDIF
ENDIF
因此再激光焊过程中出现没有F7时,只需要看是否出现F200,如果没有F200就证明是激光设备的事,如果有F200证明是送丝报错了,直接观察送丝机就好了。
机器人
206文章
27025浏览量
201379 -
激光焊接
2文章
404浏览量
20687
原文标题:机器人激光焊VASS标准中F1,F2,F7的各用途
文章出处:【微信号:gh_a8b121171b08,微信公众号:机器人及PLC自动化应用】欢迎添加关注!文章转载请注明出处。
