1.指向函数的指针
指针不光能指向变量、字符串、数组,还能够指向函数。在C语言中允许将函数的入口地址赋值给指针。这样就可以通过指针来访问函数。
还可以把函数指针当成参数来传递。函数指针可以简化代码,减少修改代码时的工作量。通过接下来的讲解大家会体会到这一点的。
/*函数指针简单讲解 *通过指向函数的指 *针调用比较两个数 *大小的程序 */ #includeusingnamespacestd; /*比较函数声明*/ intmax(int,int); /*指向函数的指针声明(此刻指针未指向任何一个函数)*/ int(*test)(int,int); intmain(intargc,char*argv[]) { intlargernumber; /*将max函数的入口地址赋值给 *函数指针test */ test=max; /*通过指针test调用函数max实 *现比较大小 */ largernumber=(*test)(1,2); cout< b?a:b); }
通过注释大家应该很容易理解,函数指针其实和变量指针、字符串指针差不多的。如果大家理解了这个小程序,那么理解起下面这个有关Nand flash的源代码就好多了。
typedefstruct{ void(*nand_reset)(void); void(*wait_idle)(void); void(*nand_select_chip)(void); void(*nand_deselect_chip)(void); void(*write_cmd)(intcmd); void(*write_addr)(unsignedintaddr); unsignedchar(*read_data)(void); }t_nand_chip; statict_nand_chipnand_chip; /*NANDFlash操作的总入口,它们将调用S3C2410或S3C2440的相应函数*/ staticvoidnand_reset(void); staticvoidwait_idle(void); staticvoidnand_select_chip(void); staticvoidnand_deselect_chip(void); staticvoidwrite_cmd(intcmd); staticvoidwrite_addr(unsignedintaddr); staticunsignedcharread_data(void); /*S3C2410的NANDFlash处理函数*/ staticvoids3c2410_nand_reset(void); staticvoids3c2410_wait_idle(void); staticvoids3c2410_nand_select_chip(void); staticvoids3c2410_nand_deselect_chip(void); staticvoids3c2410_write_cmd(intcmd); staticvoids3c2410_write_addr(unsignedintaddr); staticunsignedchars3c2410_read_data(); /*S3C2440的NANDFlash处理函数*/ staticvoids3c2440_nand_reset(void); staticvoids3c2440_wait_idle(void); staticvoids3c2440_nand_select_chip(void); staticvoids3c2440_nand_deselect_chip(void); staticvoids3c2440_write_cmd(intcmd); staticvoids3c2440_write_addr(unsignedintaddr); staticunsignedchars3c2440_read_data(void); /*初始化NANDFlash*/ voidnand_init(void) { #defineTACLS0 #defineTWRPH03 #defineTWRPH10 /*判断是S3C2410还是S3C2440*/ if((GSTATUS1==0x32410000)||(GSTATUS1==0x32410002)) { nand_chip.nand_reset=s3c2410_nand_reset; nand_chip.wait_idle=s3c2410_wait_idle; nand_chip.nand_select_chip=s3c2410_nand_select_chip; nand_chip.nand_deselect_chip=s3c2410_nand_deselect_chip; nand_chip.write_cmd=s3c2410_write_cmd; nand_chip.write_addr=s3c2410_write_addr; nand_chip.read_data=s3c2410_read_data; /*使能NANDFlash控制器,初始化ECC,禁止片选,设置时序*/ s3c2410nand->NFCONF=(1<<15)|(1<<12)|(1<<11)|(TACLS<<8)|(TWRPH0<<4)|(TWRPH1<<0); } else { nand_chip.nand_reset = s3c2440_nand_reset; nand_chip.wait_idle = s3c2440_wait_idle; nand_chip.nand_select_chip = s3c2440_nand_select_chip; nand_chip.nand_deselect_chip = s3c2440_nand_deselect_chip; nand_chip.write_cmd = s3c2440_write_cmd; #ifdef LARGER_NAND_PAGE nand_chip.write_addr = s3c2440_write_addr_lp; #else nand_chip.write_addr = s3c2440_write_addr; #endif nand_chip.read_data = s3c2440_read_data; /* 设置时序 */ s3c2440nand->NFCONF=(TACLS<<12)|(TWRPH0<<8)|(TWRPH1<<4); /* 使能NAND Flash控制器, 初始化ECC, 禁止片选 */ s3c2440nand->NFCONT=(1<<4)|(1<<1)|(1<<0); } /* 复位NAND Flash */ nand_reset(); }
这段代码是用于操作Nand Flash的一段源代码。首先我们看到开始定义了一个结构体,里面放置的全是函数指针。他们等待被赋值。然后是定义了一个这种结构体的变量nand_chip。
然后是即将操作的函数声明。这些函数将会被其他文件的函数调用。因为在这些函数里一般都只有一条语句,就是调用结构体的函数指针。接着往下看,是针对两种架构的函数声明。然后在nand_init函数中对nand_chip进行赋值,这也就是我们刚刚讲过的,将函数的入口地址赋值给指针。
现在nand_chip已经被赋值了。如果我们要对Nand进行读写操作,我们只需调用nand_chip.read_data()或者nand_chip.write_cmd()等等函数。这是比较方便的一点,另一点,此代码具有很强的移植性,如果我们又用到了一种芯片,我们就不需要改变整篇代码,只需在nand_init函数中增加对新的芯片的判断,然后给nand_chip赋值即可。所以我说函数指针会使代码具有可移植性,易修改性。
如果大家想对函数指针有更深的理解建议看一下这篇博文:http://www.cnblogs.com/CBDoctor/archive/2012/10/15/2725219.html
写的超赞,博主很佩服^_^
2.C语言操作寄存器
在嵌入式开发中,常常要操作寄存器,对寄存器进行写入,读出等等操作。每个寄存器都有自己固有的地址,通过C语言访问这些地址就变得尤为重要。
#defineGSTATUS1(*(volatileunsignedint*)0x560000B0)
在这里,我们举一个例子。这是一个状态寄存器的宏定义。首先,通过unsigned int我们能够知道,该寄存器是32位的。因为要避免程序执行过程中直接从cache中读取数据,所以用volatile进行修饰。
每次都要重新读取该地址上的值。首先(volatile unsigned int*)是一个指针,我们就假设它为p吧。它存储的地址就是后面的0x560000B0,然后取这个地址的值,也就是p,所以源代码变成了((volatile unsigned int *)0x560000B0),接下来我们就能直接赋值给GSTATUS1来改变地址0x560000B0上存储的值了。
/*NANDFLASH(seeS3C2410manualchapter6)*/ typedefstruct{ S3C24X0_REG32NFCONF; S3C24X0_REG32NFCMD; S3C24X0_REG32NFADDR; S3C24X0_REG32NFDATA; S3C24X0_REG32NFSTAT; S3C24X0_REG32NFECC; }S3C2410_NAND; staticS3C2410_NAND*s3c2410nand=(S3C2410_NAND*)0x4e000000; volatileunsignedchar*p=(volatileunsignedchar*)&s3c2410nand->NFSTAT;
有时候,你会看到这样一种情况的赋值。其实这和我们刚刚讲过的差不多。只不过这里是在定义了指针的同时对指针进行赋值。这里首先定义了结构体S3C2410_NAND,里面全部是32位的变量。
又定义了这种结构体类型的指针,且指向0x4e000000这个地址,也就是此刻s3c2410nand指向了一个实际存在的物理地址。s3c2410nand指针访问了NFSTAT变量,但我们要的是它的地址,而不是它地址上的值。所以用&取NFSTAT地址,这样再强制转换为unsigned char型的指针,赋给p,就可以直接通过p来给NFSTAT赋值了。
3.寄存器位操作
#defineGPFCON(*(volatileunsignedlong*)0x56000050) GPFCON&=~(0x1<<3); GPFCON |= (0x1<<3);
结合我们刚刚所讲的,首先宏定义寄存器,这样我们能够直接给它赋值。位操作中,我们要学会程序第2行中的,给目标位清0,这里是给bit3清0。第3行则是给bit3置1。
直接来源 | 嵌入式大杂烩
原文:https://www.cnblogs.com/CrazyCatJack/p/6080266.html
|整理文章为传播相关技术,版权归原作者所有|
|如有侵权,请联系删除|
原文标题:嵌入式开发中常见3个的C语言技巧,很实用!
文章出处:【微信公众号:嵌入式ARM】欢迎添加关注!文章转载请注明出处。
嵌入式
4981文章
18274浏览量
288342 -
C语言
180文章
7528浏览量
128411
文章出处:【微信号:gh_c472c2199c88,微信公众号:嵌入式微处理器】欢迎添加关注!文章转载请注明出处。
