KSC - Sealed Tact Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC-ST - Sound Tunable Tact Switch - C&K Components
2022-11-04 17:22:44
KSC1008 - NPN Epitacial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC1008COBU - NPN Epitacial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC1008CYBU - NPN Epitacial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC10150SHLFS - Sealed Tact Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC10J50SHLFS - Sealed Tact Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC1150SHLFS - Sealed Tact Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC11J50SHLFS - Sealed Tact Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC1J50SHLFS - Sealed Tact Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC2073 - TV Vertical Deflection Output - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2223 - High Frequency Amplifier - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2310 - High Voltage Power Amplifier - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2316 - Audio Power Amplifier Applications - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2328A - NPN Transistor - Weitron Technology
2022-11-04 17:22:44
KSC241GLFS
2023-03-29 22:45:53
KSC241J-LFS
2023-03-29 22:38:49
KSC2859Y - Low Frequency Power Amplifier - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2883 - Low Frequency Power Amplifier - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2883_06 - NPN Epitaxial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC2982 - NPN Epitaxial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3076 - Power Amplifier Applications - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3123R - Mixer for UHF TV Tuner - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3123YMTF - Mixer for UHF TV Tuner - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3503 - NPN Epitaxial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3503CSTU - NPN Epitaxial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3503DSTU - CRT Display, Video Output - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3503FSTU - NPN Epitaxial Silicon Transistor - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3552 - High Voltage and High Reliabilty - Fairchild Semiconductor
2022-11-04 17:22:44
KSC3569 - High Speed Switching Application - Fairchild Semiconductor
2022-11-04 17:22:44
KSC388 - TV Final Picture IF Amplifier Applications - Fairchild Semiconductor
2022-11-04 17:22:44
KSC441ST1LFS - Sound Tunable Tact Switch - C&K Components
2022-11-04 17:22:44
KSC44JST1LFS - Sound Tunable Tact Switch - C&K Components
2022-11-04 17:22:44
KSC46JST1LFS - Sound Tunable Tact Switch - C&K Components
2022-11-04 17:22:44
KSC4D - Sealed Detect Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC4D - Sealed Detect Switch for SMT - ITT Industries
2022-11-04 17:22:44
KSC4D150SHLFS - Sealed Detect Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC4D1G - Sealed Detect Switch for SMT - C&K Components
2022-11-04 17:22:44
KSC5 - Tact Switch with Rocker Option for SMT - C&K Components
2022-11-04 17:22:44
KSC5021 - Silicon NPN Power Transistors - Savantic, Inc.
2022-11-04 17:22:44
KSC5024 - High Voltage and High Reliabilty - Fairchild Semiconductor
2022-11-04 17:22:44
KSC5027 - Silicon NPN Power Transistors - Savantic, Inc.
2022-11-04 17:22:44
KSC5027R - High Voltage and High Reliability - Fairchild Semiconductor
2022-11-04 17:22:44
KSC51JROHS - Tact Switch with Rocker Option for SMT - C&K Components
2022-11-04 17:22:44
KSC523J - Tact Switch with Rocker Option for SMT - ITT Industries
2022-11-04 17:22:44
KSC5242 - Audio Power Amplifier - Fairchild Semiconductor
2022-11-04 17:22:44
5A的电流条件下传输100W的功率• 增加了板件保持功能和EMI防护功能,实现强固式 设计• 高达10,000次使用寿命 电气特性:• 电压额定值:30V Max• 额定电流:5A• 触点电阻:Max
2019-02-21 09:46:02
AD5640BRJZ的使用寿命/年限是多少?
2023-12-11 08:18:38
我们计划在我们的项目中使用英飞凌的蓝牙模块之一。
AIROC 蓝牙模块的使用寿命是多少(寿命终止)? 我们正在寻找一款支持经典蓝牙配置文件或支持双模式(经典和 BLE)的模块。
我们正在寻找一款理想情况下可以获得5年技术支持的蓝牙模块。 3年也是一个不错的术语。
2024-03-01 13:57:03
ARK推出新一代250V MOS器件 近日,成都方舟微电子有限公司(ARK Microelectronics, Co., Ltd.,简称ARK)推出新一代250V MOSFET系列产品,包括N型
2011-04-19 15:01:29
FKP1Y021006F00KSC9
2023-03-28 13:49:51
自动流程跑一次需要写一次FLASH操作,那么FLASH很快就会挂掉。原因很简单,因为FLASH的一般寿命都在10万次左右,好点的也就100万次,按照客户要求去计算的话,一年最大可能要写FLASH将近
2020-05-04 05:55:58
与传统照明器件相比,LED非常耐用(使用寿命很长),发生灾难性故障的几率微乎其微,并且光度下降和颜色变化都非常缓慢。一般而言,LED只是固态照明系统中的一小部分,在照明系统中,LED的性能(如亮度
2019-04-19 06:21:15
M451中,FMC控制flash读写,数据可否做到写100万次?要用什么机制?有没有例程?
2023-06-25 08:02:41
MKS0B041000F00KSC9
2023-03-28 13:49:37
MKS2B044701K00KSC9
2023-03-28 13:18:00
出水的质量能够达到合格的标准。 过滤器滤芯使用过程中,可能会有很多细小的颗粒物质,这些颗粒物质的存在很容易造成堵塞,优先次更换之前可以考虑使用水冲洗,但是如果冲洗效果不理想,还是要更换新的滤芯。但是做到以上几点,相信可以大大延长过滤器滤芯的使用寿命,减少频繁更换滤芯的次数。
2020-05-14 15:44:51
。那么如何将老化的时间尽可能后退呢?以下几个小绝招可以让你的屏幕延长使用寿命。 1、平时要减少屏幕在日光下暴晒的可能。白天使用,尽量避免阳光直射,以防屏幕受日照后,温度过高,加快老化。 2、做好日常
2013-12-30 10:53:19
如何延长蓄电池的使用寿命?
2021-06-18 06:03:40
作为电子产品的重要部件电解电容,在开关电源中起着不可或缺的作用,它的使用寿命和工作状况与开关电源的寿命息息相关。在大量的生产实践与理论探讨中,当开关电源中电容发生损坏,特别是电解电容冒顶,电解液外溢
2021-03-07 08:23:57
影响CLL电容使用寿命的因素有哪些?
2021-09-23 07:44:52
通过放大器采集并记录,是位移传感器中测量行程最长的一款产品,该产品使用寿命最高可达1000万次,那么影响该产品寿命的因素有哪些呢?下面众标小编为您一一陈述。以下四种情况,将会影响拉线位移传感器
2018-12-04 11:34:23
2018-12-07 10:18:10
中绝大多数仍可正常运行很多年。如果电表的使用寿命可以延长,直至精度下降之前才及时更换,该有多好? 延长电表的使用寿命可带来惊人的高回报。假设有一家电力公司,其花在单只电表及其安装上的成本为100欧元
2018-07-24 08:15:18
多方面因素,该产品在正常使用次数拉出和弹回可达到800万/次。一只传感器如果超出这个范围,就有可能减少使用寿命。文章出自济南精量电子`
2020-07-04 11:30:45
长不可能长。因此,要温度探头精度高使用寿命长先明确技术要求是硬道理。第一次选型的项目不妨咨询温度传感器的生产厂家,说明使用环境由厂家技术人员提出建议确定规格尺寸等参数,制作样品进行测试,测试的过程中对原来没有考虑到的地方进行补充修改,最终用上跟产品高度匹配的温度探头。`
2019-02-21 11:30:02
如题,如何去计算正要研发的一款产品的使用寿命,是不是应该从使用的电子元器件的使用寿命去整体权衡,有没有什么手册可以查询,或者有没有什么软件可以输入所使用的电子元器件,然后能计算出理论上这款产品的使用寿命?
2015-06-06 16:26:56
2015-06-06 16:28:36
的地应力慢慢释放出来。电阻负载使用寿命的指标值只有根据取样检测,根据试品检测换算出商品的预估使用寿命。由于这类检测最少必须1千钟头,航空航天的运用则将会必须达到一万钟头的检测,且这类检测是毁灭性的试验
2020-07-03 17:31:07
变化≤3倍 超级电容C型产品特点: 1. 充电速度迅速,充电30秒即可达到额定容量 2. 循环使用寿命长,使用次数高达50万次,折算年限接近30年 3. 放电能力强,效率高,损耗小 4. 功率密度较低
2021-09-08 08:26:19
等离子的使用寿命是多久? 答: 等离子电视的使用寿命大约为6
2009-05-24 18:00:55
法拉组合电容产品特点: 1.充电速度迅速,充电30秒即可达到额定容量 2.循环使用寿命长,使用次数高达50万次,折算年限接近30年 3.放电能力强,效率高,损耗小 4.功率密度较低 5.温度特性良好
2021-09-03 11:15:15
主要特性与技术指标SP4T 配置磁保持1000 万次的使用寿命在高达 500 万次的使用寿命中具有 0.03 dB 的保证
2022-08-03 11:13:06
依立KSC10电子瓦罐电路图
2008-11-17 11:14:571622
依立KSC25 KSC30 KSC40电子瓦罐电路图
2008-11-17 11:15:422742
依立KSC60电子瓦罐电路图
2008-11-17 11:16:012826 Vishay推出具有两百万次循环寿命的高可靠性面板电位计P30L
Vishay推出升级版本的P30L紧凑型面板电位计,将其循环寿命比原来增加了一倍,达到额定功率下使用2百万次,而升
2009-11-04 15:24:25439 电池耐用技巧
电池要耐用 方法很重要
钟先生问:最近发觉电动车电池不耐用,如何延长电池的使用寿命?
2010-04-03 08:46:21458 全球领先的电动机械开关、智能卡互联器件和高可靠性连接器制造商 CK Components 推出 4 款 5,000,000 周期超长使用寿命开关,扩大了 KSC 系列密封 SMT 轻触开关的阵容
2018-06-08 11:30:001514 智能卡互联器件和高可靠性连接器制造商C&K Components新型高可靠性工效学键盘开关,面向需要长使用寿命的应用,包括游戏、工业、专业和工作站键盘。KBD系列开关的使用寿命很长,达到50,000,000周期,提供2种触觉响应和操纵力选项。
2018-04-13 11:03:001104 C&K, 全球最值得信赖的高品质机电开关品牌之一, 今天在拉斯维加斯的 EDS 峰会上宣布推出新型医疗开关产品线, 专门用于高压杀菌安全的产品。C&K 的新型医疗开关系列能够帮助医疗界符合当今严格
2018-05-29 17:26:002196 KSC康晒币虚拟区块链分红系统开发找(李生183-1834-8747微电同号)KSC康晒币投资理财系统开发、KSC康晒币矿机挖矿理财系统源码平台搭建1、KSC项目全球共分五大运营中心,分别为瑞士运营
2018-07-16 10:07:48422 C&K,今天宣布推出新款BDB DIP(双列直插或拨码)开关。这一传统的全剖面拨码开关,可为所有需要可靠拨码开关和凸柄(以方便操作)的应用,提供新一代有价格竞争力的解决方案。
2019-04-02 15:27:151012 电子发烧友网为你提供()KSC388相关产品参数、数据手册,更有KSC388的引脚图、接线图、封装手册、中文资料、英文资料,KSC388真值表,KSC388管脚等资料,希望可以帮助到广大的电子工程师们。
2019-04-18 22:15:10
电子发烧友网为你提供()KSC1674相关产品参数、数据手册,更有KSC1674的引脚图、接线图、封装手册、中文资料、英文资料,KSC1674真值表,KSC1674管脚等资料,希望可以帮助到广大的电子工程师们。
2019-04-18 22:15:10
电子发烧友网为你提供()KSC2223相关产品参数、数据手册,更有KSC2223的引脚图、接线图、封装手册、中文资料、英文资料,KSC2223真值表,KSC2223管脚等资料,希望可以帮助到广大的电子工程师们。
2019-04-18 22:15:10
各个厂家的电力电容器的使用寿命都是不同的,拿库克库伯并联电力电容器来说,使用寿命15年以上,这个数值是经过数万次的实验得出来的。
2019-11-04 11:01:123874 继电器的电气寿命通常只有10万次,如想再提供寿命那么器件的可选范围可能就小了,且成本居高不下。经实际测试,用零电压吸合零电流释放这一技术,可以极大的提高继电器的寿命至50万次到100万次,且上面提到的这些不良现象的发生概率降低很多。
2020-01-20 14:46:0015330 电容屏的使用寿命是很长的,基本上三到五年。一般是充电3万次左右,正常情况下。
2020-06-29 15:33:305304 有几种方法可以保持电池寿命(以充电/放电循环次数计)。换句话说,电池达到其使用寿命之前的使用寿命,而不是该循环充电的使用寿命。
2022-03-10 17:25:082964 KSC4 TE 开关的尺寸为 6mm x 6mm, 高度为 5.2mm, 提供三种操作力, 分别为 1.6、2.8 和 4N。其紧凑的尺寸和设计的灵活性给设计师提供了更多的空间, 方便他们为最终产品
2022-11-08 11:06:481190 相信大家都发觉薄膜开关的寿命很长,其实薄膜开关可使用时间通常都能够保证使用一百万次不损坏,那么为什么薄膜开关的使用寿命这么长呢?
2023-04-14 16:21:55558 很多朋友购物最关心的是商品的使用寿命。世界上没有什么能长久,贴片电容也是如此。今天,小编将带你了解电容器的使用寿命。
标称最高温度85℃,在85℃环境温度下,使用寿命可达1000小时
2023-06-18 15:57:015994 Littelfuse公司近日宣布推出MITI-7L磁簧开关系列,这是其超小型磁簧开关产品的最新突破。与现有的7mm磁簧开关相比,MITI-7L系列具有更长的使用寿命和更高的可靠性,可实现数百万次循环。
2024-02-01 16:31:04413
查看更多
